Oil Pressure - 394
Old Jun 19, 2016 | 02:13 PM
DynamicIdiot's Avatar
64 Dynamic 88
Oil Pressure - 394
Hi Everyone,
This is a question for those of you running a 394 and who happen to have an oil pressure gauge. With the engine warm, what is your oil pressure range, or at least idle pressure and cruising speed pressure?
Mine has 35-40 when cruising and 5-10 at idle, depending on the outside temperature, which can get pretty high in New Mexico.
Cheers,
Jason
Old Jun 19, 2016 | 02:31 PM
67 Cutlass Freak's Avatar
Mine has 40 PSI at cruising speed and 20 PSI at idle in gear, engine at normal operatinng temperature. My car is a 1964 dynamic 88 all original with 67,000 miles.
Old Jun 19, 2016 | 03:09 PM
64 Dynamic 88
Awesome, thanks for sharing. My idling pressure is in drive as well...goes up a little out of drive. My engine is pretty high mileage so I'm planning a rebuild; just trying to get a sense of what's "normal" in terms of oil pressure.
Cheers,
Jason
PS: Mine is a 64 Dynamic 88 as well. about 40k showing on the odometer, but I'm not sure of the actual mileage...it's at least 140k.
Old Jun 19, 2016 | 04:24 PM
It also is dependent on oil viscosity.
Old Jun 19, 2016 | 04:28 PM
redoldsman's Avatar
Proud Viet Nam Veteran
My 324 runs about 55-60 on the highway and idles at 30-35. It is not a new engine but I was surprised. That is the factory gauge which might be off a little.
394 Skyrocket
Jun 19, 2013 10:19 PM
foreverolds
Dec 1, 2012 07:07 PM
Railguy
Tech Editor's Desk
Jul 25, 2010 02:36 PM
Swed Olds
Jul 15, 2010 12:21 AM
