394 Dual Carbs Questions
Old September 12th, 2019, 09:55 PM
  #121
Phantom Phixer
Charlie Jones's Avatar
Originally Posted by bccsrc
what temp thermostat should i get?
180
Charlie Jones is offline
Old October 5th, 2019, 10:59 AM
  #122
bccsrc's Avatar
180
Thanks Charlie.
What oil weight should I get? Looks like I ran out of time to get this going this summer so I won't have it running until spring time hopefully.
What type of transmission fluid should I get?
I need to come up with some type of bracket to hold the carb return spring. I'm thinking something from the rear carb to the intake bolt near the first few letters of Offenhauser. Either that or a bracket off the rear of the front carb.
bccsrc is offline
Old October 5th, 2019, 04:47 PM
  #123
Phantom Phixer
I,m partial to Mobil 1 oil .
The factory originally recommended 20 weight oil in 1964 .
Today,s rough equivalent is 20w-50 .
Change oil and filter after the first 30 minutes of operation , to get any dirt that may have gotten into the engine.
Use Dexron III / Mercon trans fluid
I think a bracket for those throttle springs could be made from a 10 or 12 inch piece of 3/4 in, channel iron .
Drill two holes to mount it to the rear studs of the front carb .
Drill a small hole in the end for the springs .
The front carb should also have a return spring
What are you going to do about connecting the throttle linkage to the transmission control linkage ?
"Old Jim " needs to know where the position of the throttle plates are , to shift properly .
Without this throttle to trans linkage properly connected and adjusted "Old Jim " will do some hateful things .
And just may burn himself up doing it .
Old October 10th, 2019, 11:37 PM
  #124
bccsrc's Avatar
I’m ordering a second bracket for the rear carb but these seem to work well for throttle return brackets.
I think for the transmission adjustment I may purchase the tool that I’ve seen on here. I’ve thought about just 3D printing it.
bccsrc is offline
Old October 12th, 2019, 11:36 AM
  #125
Phantom Phixer
The adjustment tool won't do you any good , unless you have the linkage .
The items I have circled here are what is needed .
Old October 12th, 2019, 04:01 PM
  #126
bccsrc's Avatar
I don't see how that will be possible with my existing setup unless I'm missing something. Is the bell crank assy something that can be purchased or added to my setup?
bccsrc is offline
Old October 12th, 2019, 09:22 PM
  #127
Phantom Phixer
I THINK I have most of that stuff . IF I can find it .
You can have it for the postage . PM me .
I took it off my Starfire motor , because I have a 4 speed stick .
Old October 12th, 2019, 10:15 PM
  #128
bccsrc's Avatar
Thanks Charlie, that would be great. I will pay you for it. Very much appreciated!
bccsrc is offline
Old October 15th, 2019, 09:47 AM
  #129
Phantom Phixer
Throttle linkage
Here is what I have . PM me with your shipping address .
I also have this bellcrank , if you need it ;
Old October 15th, 2019, 12:49 PM
  #130
bccsrc's Avatar
Hi Charlie,
I sent you a PM.
Thanks again!
bccsrc is offline
Old October 23rd, 2019, 02:09 PM
  #131
bccsrc's Avatar
Thanks Charlie Jones
I wonder if this would be better being posted out in the transmission group. Does any one have a working picture of this bell crank? I'm not 100% sure how it works and if I could somehow come up with a bracket if needed. The springs on the carbs are a work in progress. I don't plan on leaving the spring there for the rear carb. There does seem to be more room up on the front carb for the bell crank but I would have to remove the progressive linkage I would think.
bccsrc is offline
Old October 24th, 2019, 08:16 PM
  #132
Phantom Phixer
carb linkage idea
Here is one way to hook up the linkage and make it work;
take this rod and hook it up just the way it was here ;
Then , make a bracket and pivot for the bellcrank . in it's stock location .Pairing the second throttle rod with the first .
Old November 7th, 2019, 12:38 PM
  #133
bccsrc's Avatar
I’m a little confused on exactly what the bell crank is going. Can you explain this to me? I’ve seen a bell cranke in jegs that seems like it might be an easier install but I’m still confused on what’s happening here.
bccsrc is offline
Old November 8th, 2019, 05:52 PM
  #134
Phantom Phixer
The bellcrank should be mounted on a stud that is in the same position as it would be in a stock four barrel engine .
I can give you an exact location , but give me a couple of days to measure this from my engine .
The link between the bellcrank and the carb would not be used . The bellcrank would be there simply to connect the throttle rod to the trans linkage .
A second throttle rod ( which you already have ) would connect the throttle rod to the carbs .
Old December 18th, 2019, 08:02 PM
  #135
Phantom Phixer
Sorry for the slow reply .
The center of the end of the bellcrank pivot stud should be mounted exactly two and 11 sixteenths inch above the rear center manifold stud , like this ;
You will need to make a bracket that will bolt to the front studs of the rear carb. Like this ;
This linkage will be eliminated , as you have other linkage to the carbs ;
Old December 18th, 2019, 10:10 PM
  #136
bccsrc's Avatar
Thank you. Once it warms up a little I will get busy working on this.
bccsrc is offline
Old October 28th, 2021, 09:45 PM
  #137
bccsrc's Avatar
I went over and took the hood off the Oldsmobile today to get ready to install the engine and transmission. I guess after sitting since 2014 the engine compartment doesn’t look like this any longer.
I’m trying to not feel overwhelmed with how much work needs to be done to get the Olds back up to what it used to be.
bccsrc is offline
Old October 29th, 2021, 06:03 AM
  #138
Phantom Phixer
Glad to see you back at it .
Old October 29th, 2021, 03:18 PM
  #139
bccsrc's Avatar
Me too!! I painted the engine compartment. Just a little fresh paint and looking great!
I need to look in the manual to see how to replace the heater core while I have the engine out. The old one leaked so it was bypassed.
I don’t have a picture but I saw that one of the A-arms is missing the bolt on one side. Not sure how long it has been like that.
bccsrc is offline
Old October 30th, 2021, 06:29 PM
  #140
bccsrc's Avatar
Well, now what? That definitely isn't going to lift the engine and transmission into place without pulling the front end off. I'm not doing that!
What do you think the engine and transmission weigh? I'm thinking close to 1/2 a ton.
bccsrc is offline
Old October 30th, 2021, 08:33 PM
  #141
Phantom Phixer
I don't think that shop crane is anywhere big enough for the job .
Not capacity wise so much , but I don't think it will lift the engine high enough .
Perhaps you can rent a larger shop crane .
That engine is 750 pounds alone , add another 150 to 200 pounds for a transmission , and you are very close to 1/2 ton .
If you remove the radiator support crossbar it will make it somewhat easier .
Old November 1st, 2021, 03:38 AM
  #142
Any chance you could accommodate an overhead chain block hoist? They're modestly priced (affordable) at the 3 Ton capacity (~$100 - $150). Pull car backwards, lift, pull car forwards, lower. Just an idea.
Vintage Chief is online now
Old November 2nd, 2021, 10:18 AM
  #143
Don R.'s Avatar
Did you pull the engine and trans out as a single unit? If so what did you use to lift? Biggest issue to do that is the ability to lift it high enough to clear the front and then sharply angling it into place, the car itself may have to be raised for the trans tailhousing to clear.
Don R. is offline
Old November 2nd, 2021, 10:54 AM
  #144
bccsrc's Avatar
The EX wife thought in the divorce that she needed the engine hoist that I used to pull the engine and transmission out originally. I should have listed it on the items I wanted. Honestly I can't remember what model it was. I will probably just have to rent one for $40 a day or get this one from Harbor Freight. It's 2 ton and has a reach of 86 inches for 1 ton versus the one I have now 79 inches on 1/2 ton in the picture above. It's currently $270 though. I'm hoping it goes on sale or has a coupon that I can use on it soon.
The Oldsmobile is in a storage unit that I rent. I don't think I could get an overhead crane in there.
Looking through pictures I found a pic of the old engine hoist. I think that is from Harbor Freight. Probably 2 ton since the 1 ton version I have wont work.
bccsrc is offline
Old November 4th, 2021, 10:04 AM
  #145
Don R.'s Avatar
That looks like my 2 ton, it will do the job but you also need enough ceiling height to clear.
Don R. is offline
Old June 25th, 2022, 12:12 PM
  #146
bccsrc's Avatar
Well it’s in place. It’s been way too long to get here.
Just need to attach the motor and transmission mounts next.
bccsrc is offline
Old July 9th, 2022, 12:29 PM
  #147
bccsrc's Avatar
Springs
What do these springs do and how important are they? I don’t have them.
bccsrc is offline
Old July 9th, 2022, 04:38 PM
  #148
Phantom Phixer
Those springs are important. As well as the spacer.
They maintain a prescribed amount of pressure holding the pipe to the manifold.
This allows the pipe to maintain a good seal through hot and cold cycles.
The springs and spacers occasionally pop up on E-Bay. The OEM number for the spring is 587575. and the spacer is 587574.
Old July 9th, 2022, 04:44 PM
  #149
bccsrc's Avatar
Thanks Charlie. I ordered the springs. Not sure if they were ever installed or not when dad had it.
I can’t find the spacer at the moment. Any idea what size they are?
I need to find one more of the exhaust seals. My Fel pro kit only had one in it.
bccsrc is offline
Old July 10th, 2022, 02:23 PM
  #150
bccsrc's Avatar
My temp sensor won’t fit in my offenhauser intake. It turns just about 1-2 times before it seems like it’s creating new threads.
Well that sucks! Might have to ask a friend to weld on a new bolt.
bccsrc is offline
Old July 10th, 2022, 03:46 PM
  #151
OLDSter Ralph's Avatar
#1 The intake manifold threads are far from clean enough to install the sensor.
OLDSter Ralph is offline
Old July 10th, 2022, 03:58 PM
  #152
bccsrc's Avatar
Looks like the right thread. Maybe I need to run a tap through there. I might have one that size.
bccsrc is offline
Old July 10th, 2022, 05:05 PM
  #153
Let me re-phrase that. They need to be cleaned, threads chased or whatever you want to call it. The thread major diameter damage on the first thread of the sendor is a clear indication.
Put plenty of grease on the tap to trap particles from running the tap in. You may also try a good "Wet-Vac" to suck out the particles as you run the tap in.
Old July 11th, 2022, 08:52 AM
  #154
Dynoking's Avatar
The temp sensor and intake thread pitch is pipe thread.(NPT) Do not try to use SAE or NC.
Dynoking is offline
Old July 11th, 2022, 10:57 AM
  #155
bccsrc's Avatar
I wonder what size NPT tap I would need? 3/4?
bccsrc is offline
Old July 11th, 2022, 11:02 AM
  #156
bccsrc's Avatar
Gas Tank Flush
The Olds has been sitting probably 8 years. I should probably flush the gas tank and put in fresh gas.
Does this involve removing the gas tank?
bccsrc is offline
Old July 11th, 2022, 11:40 AM
  #157
Dynoking's Avatar
My guess is 3/8" or 1/2". Perhaps someone here can help us out or take temp sensor to hardware store or tool supply and match it up with the tap.
Dynoking is offline
Old July 11th, 2022, 08:54 PM
  #158
Phantom Phixer
No, you do not need to remove the tank.
You can siphon the gas out safely by using the following method .
1. Raise the car, either on a hoist , or jack up the rear end so you can get underneath with a gas can. Use jackstands.
2. Get two 5 gallon gas cans and a 5 foot length of 3/8 fuel hose.
3. Remove the fuel hose that goes from the tank to the fuel pump.
4. Connect the length of 3/8 fuel hose to the gas tank and put the other end of the hose into one of the gas cans.
5. Wrap a rag around an air blow nozzle and blow a quick shot of air into the gas filler hole to start the siphon. ( careful, not too much)
6 When the first can fills up, switch the hose over quickly to the second can and empty the first one.
Old July 23rd, 2022, 04:44 PM
  #159
bccsrc's Avatar
I’m having a hard time figuring this bell crank out. Does it need to have linkage to the carburetor’s?
bccsrc is offline
Old July 23rd, 2022, 05:33 PM
  #160
cfair's Avatar
Just checking out this fun dual quad thread. It’s a generation older than my ‘66’s, but I spent some time figuring out the gas pedal and kickdown switches a while back.
Perhaps this thread will help you:
https://classicoldsmobile.com/forums...vicing-149216/
Chris
cfair is offline
Quick Reply: 394 Dual Carbs Questions
