1967 400E with 1965 A Heads
Old May 6, 2021 | 02:41 PM
Thirdcoast's Avatar
Question 1967 400E with 1965 A Heads
I have searched everything and read all that I could find about BBO Heads and cannot find the answer.. HELP Please
I have a 67 400E with 1965 A heads and want to know if the heads have the exhaust crossover ??
The engine is stock and runs fine, I do not want to tear into it just to find out this, but I would like to know for possible future mods to this engine.
Thanks,
Thirdcoast
Old May 6, 2021 | 02:47 PM
As far as I know, all Olds heads have the exhaust crossovers. Only the later high performance engines (W-30, H/O) had one crossover blocked.
Old May 6, 2021 | 03:06 PM
Oldsmaniac's Avatar
It has been said the A heads do not have the AIR bumps in the exhaust ports making for a bit better flow.
Old May 6, 2021 | 03:32 PM
2blu442's Avatar
Yes, I agree with Oldsmaniac. Although I have come across a couple A heads with the AIR bumps, very much out of the ordinary. They do have the exhaust crossover but 65-68 had smaller openings than the later heads.
Old May 6, 2021 | 08:33 PM
therobski's Avatar
X3 guys
Old May 7, 2021 | 05:28 AM
As noted, most A heads did not have A.I.R. bumps. These were apparently added late in the model year in anticipation of the looming CA emissions requirements for the 1966 model year.
The other thing to note about the A castings is that they use 3/8" studs with unique rocker trunnions. Those parts are not available today, so replacements can be problematic. You can use aftermarket roller rockers on 3/8 studs, but you still need to machine the pads on the heads to allow clearance for the pushrod guide plates.
Old May 7, 2021 | 05:42 AM
Thirdcoast's Avatar
Thumbs up A Heads
Thanks everyone, that's what I needed to know..
Thirdcoast
Old May 7, 2021 | 05:11 PM
For what it's worth, a 67 400 E had C heads, so one with A heads is not stock. Perhaps I misunderstood and you meant no work has been done on the engine other than the head swap.
Old May 7, 2021 | 08:09 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Block off the crossover in the intake, not the heads. Easier to do, (weld in the iron plugs), and easier to machine out if it ever needs to be reversed. Dont fear the Olds iron intake. Thou its not light.
20 years on this intake paint.
Old May 9, 2021 | 07:53 AM
67OAI's Avatar
Old(s)GuysRule
I may or may not receive flack for this but regarding the use of "A" cylinder heads, the later style trunnions/pedestals can be used by drilling the bolt holes in the pedestal to accommodate a 3/8" bolt.
DENT
Apr 28, 2016 08:08 AM
67442nut
Nov 19, 2015 06:51 PM
69CutlassAlex
May 19, 2013 11:50 AM
flamez
Mar 22, 2010 01:57 PM
80_cutlass
Feb 16, 2010 10:33 AM
