1966 fuel pump
Old January 27th, 2017, 04:11 PM
Olds75's Avatar
1966 fuel pump
I have a 1966 olds 442, can some one tell me if the connection for the fuel pump should be on top or bottom?
Olds75 is offline
Old January 28th, 2017, 07:23 AM
Rather than resurrecting an old thread that is only slightly related, you're better off starting a new thread with your question.
ALL Olds fuel pumps mount with the ports UP. This is opposite of a Chevy.
joe_padavano is offline
Old January 28th, 2017, 08:59 AM
66-3X2 442's Avatar
A 66 442 uses a return line and I do not see one on the pump in the picture. I use a Carter M4516 that's ethanol compatible and has the right connections.
66-3X2 442 is offline
Old January 28th, 2017, 09:02 AM
The blue 455 in the photo was not described as nor intended to represent a 1966 442 motor, it was simply to illustrate that ALL 1964-1990 Olds fuel pumps mount with the fittings on top, which was his question. I'm guessing the OP is confused because he has previously looked at Chevy pumps.
Old January 28th, 2017, 02:09 PM
66-3X2 442's Avatar
My bad,should have paid closer attention. I promise I will try to do better in the future.
Old January 29th, 2017, 09:55 PM
Olds75's Avatar
66 Olds 442 fuel pump
Hey Joe,
Thanks for the reply, I've been a member for a while but don't post very much. Great looking engine BTW.
Olds75 is offline
Old January 30th, 2017, 05:31 AM
lemoldsnut's Avatar
66 also had an external extra diaphram of some kind not sure why but I have one off a 66 442 and here is what is looks like.
lemoldsnut is offline
Old January 30th, 2017, 07:18 AM
Not mine, just a photo I stole off of Google Images to illustrate correct pump orientation.
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
mefirst72
February 10th, 2013 06:37 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
sshriber
March 22nd, 2010 06:16 PM
Quick Reply: 1966 fuel pump
