1966 425
Old September 18th, 2013, 06:33 PM
smietana's Avatar
1966 425
Just bought BBO, what is supposed to be from a 1966 toro. Came with B heads, and intake (which I will not be using). Any help to confirm that it is what I was told would be great.
smietana is offline
Old September 18th, 2013, 06:47 PM
Oldsmaniac's Avatar
The toro 425 had larger diameter lifters, larger oil pan with crank scrapers and the oil filter housing was angled rather than vertical in respect to filter. The heads had the larger intake valves.
Oldsmaniac is online now
Old September 18th, 2013, 06:54 PM
Run to Rund's Avatar
N------T on B heads is correct for a 66 Toro
Run to Rund is offline
Old September 18th, 2013, 08:09 PM
Just the facts...
BILL DEMMER's Avatar
and the 5th pic clearly shows the "drill spot" on the rib of the timing housing shelf. congrats! definitely looks like a toro motor, arguably the best of the Olds motors.
bill
BILL DEMMER is offline
Old September 19th, 2013, 04:06 AM
smietana's Avatar
Thanks for the help, looking to build to about 400hp. would like to use the heads, will they work? Are they worth rebuilding? Any suggestions on a cam?
smietana is offline
Old September 20th, 2013, 02:58 PM
smietana's Avatar
ok, heads are at the machine shop, need to decide on springs, what should I buy?
smietana is offline
Old September 20th, 2013, 06:17 PM
Just the facts...
400 hp isn't hard. those heads will work fine. i'm not an engine build expert, so i'll defer to others on the cam. i'm pretty sure the cam dictates the springs to use though. you'll want to know a few things before choosing a cam, too. like combustion chamber cc's, piston to deck clearance, piston cc's. you may wish to do a little mild porting around the valve seat & guide area, you also might want to have hardened seats installed(do it right, do it once).
bill
steve walker
December 17th, 2019 12:32 PM
Jhall64
March 30th, 2010 05:21 PM
66ninetyeightls
March 21st, 2010 06:33 AM
raymondh
June 11th, 2008 11:50 AM
<rocket powered>
February 8th, 2005 05:05 AM
Quick Reply: 1966 425
