Qustion about VIN
Old Sep 18, 2010 | 01:52 PM
saud74's Avatar
Qustion about VIN
hi,,
I have 442 holiday coupe 1971 , can i know if the engine SB or BB from the VIN .
My car's VIN ( 344871M141705)
And there is a number on the block engine (396021F) , the engine heads have a litter (J).
also can i know if it's a manual or automatic transmission?
And what else I can know from the VIN.
thanks for any info.
Old Sep 18, 2010 | 01:59 PM
70 cutlass s's Avatar
It is a 71 that is a 442 and made in Lansing, MI
Vin doesn't tell the size of the engine in 71, not until 72.
The casting number lets us know that you have a 455, that is correct for a 71 442. The J on the heads means it has later heads on it 73-76.
Old Sep 18, 2010 | 02:05 PM
saud74's Avatar
thanks for the info ,,,
what about the transmission , can i know if it's a manual or automatic ?
Old Sep 18, 2010 | 02:45 PM
There is only a limited amount of info in the VIN for 1971 and earlier. All you can tell is:
Division (Oldsmobile)
Car line (Cutlass, Cutlass Supreme, Delta 88, etc)
Body Style
Year of manufacture
Assembly Plant
Sequential build number
In some cases, you can get limited engine data, mainly is it a six or eight cylinder car (the two digit car line numbers were different for sixes and eights in some years). You cannot prove that the car was an automatic or manual trans, nor can you tell engine size or other options. You can sometimes disprove the availability of option packages, however. For example, all W-30 and W-31 cars were built in Lansing, so while the VIN from a 1971 or earlier car cannot prove that a car is a factory W-car, it CAN prove that a non-Lansing car is NOT a W-car. And no, there are no records left of what options were on what VIN automobile.
Old Sep 18, 2010 | 09:55 PM
saud74's Avatar
thanks Joe.
Old Sep 28, 2010 | 12:07 PM
saud74's Avatar
Old Sep 28, 2010 | 12:41 PM
wmachine's Avatar
Trying to remember member
Count the pedals?
Old Sep 28, 2010 | 08:22 PM
mmurphy77's Avatar
Actually in this case the vin CAN tell you what engine the car was born with - sort of. Your vin begins with '344' which makes it a 442. The ONLY engine available in the 442 in '71 was the 455. No way to determine which 455 without documentation.
Old Sep 28, 2010 | 09:25 PM
saud74's Avatar
thanks,,
in the third line ,does the last 4 letters (B PNT) mean the color of the car??
thanks for any info ,
Old Sep 28, 2010 | 09:37 PM
Yes, 53 is the color of the body of the car, in your case Saturn Gold. and B is the roof color, black vinyl.
Old Sep 29, 2010 | 09:26 PM
saud74's Avatar
i was thinking that the body was originaly black !!
thanks for the details,
Old Oct 14, 2010 | 03:11 PM
saud74's Avatar
Any body knows the color number for ( Saturn Gold ) or how can i get it.
Old Oct 14, 2010 | 03:56 PM
6inarow's Avatar
Old Oct 15, 2010 | 04:03 AM
saud74's Avatar
thanks alot Ryan
Old Oct 15, 2010 | 06:22 AM
saud74's Avatar
but it says for Cutlass - Delta - 98 - Toronado ,,, didn't mention the 442 !
was this color also for 442 ?
Old Oct 15, 2010 | 06:30 AM
mmurphy77's Avatar
Yes 442 also. I, too, have a documented '71 442 that was code 53 Saturn Gold originally (it was repainted what appears to be code 61 Sandlewood by the PO). My plate indicates 53 53 which is solid color with no Vinyl top.
Old Oct 15, 2010 | 11:07 AM
saud74's Avatar
thanks mike
Old Oct 15, 2010 | 01:30 PM
Madmustard's Avatar
i have a saturn gold 71 442.if you can help post pics i will...
Old Oct 15, 2010 | 01:39 PM
Pics 101
When you reply make sure you are in “Advanced” If it says post a “Quick reply” hit “Advanced”
Scroll down below the box you type in and hit “ Manage Attachments” A new box will pop up.
Hit “Browse”
The hit “Upload” and wait a few secs for the pics to up load. Then close this box.
Next you can hit “Preview Post and your pictures should be there.
There is a size limit on pics
denf221
Nov 11, 2014 01:13 PM
dynamic63
Apr 9, 2014 06:58 AM
nottfromthailand
Jan 9, 2013 10:56 PM
miked
Nov 14, 2012 08:31 AM
godson
Drivetrain/Differentials
Feb 8, 2009 09:49 PM
