็Qustion? about hose to caburator
Old Jan 9, 2013 | 02:20 AM
nottfromthailand's Avatar
Hi i need to know hose in pic from pvc valve to caburator vacuum it important or not? what is duty for?
Old Jan 9, 2013 | 02:37 AM
Yellowstatue's Avatar
Carb vacuum draws engine crankcase vapours through the PCV valve which is installed in valve cover...fresh air is drawn in from opposite valve cover. Its a pollution thing./
Old Jan 9, 2013 | 02:56 AM
Thank you so much for answer. but what side is not pollution driver side or passenger side thank you again
Old Jan 9, 2013 | 03:09 AM
Fresh air is drawn in at right valve cover because of vacuum at left valve cover, and crankcase vapours go out from left valve cover via PCV valve and hose to carb, because of carb vacuum. PCV valve is a check valve in case of back fire.
Old Jan 9, 2013 | 05:13 AM
brown7373's Avatar
Although a "pollution thing", that doesn't mean you should eliminate it. It's a closed system that relieves the pressures in the crankcase and keeps those fumes in the engine to be burned, rather than letting them into the air. Don't ever eliminate it, or the unrelieved pressure will push oil all kinds of places you don't want it. You could convert back to the older style open system, but what's the point? The PVC does not rob horsepower or cause drivability issues (unless it is plugged up).
Old Jan 9, 2013 | 06:03 AM
Yes, you want to run a PCV valve. It makes no difference if the valve is in the RH or LH valve cover - some Olds motors even connect the PCV valve in the valley between intake runners. I've also seen other motors that have the valve in the oil fill tube (not Olds factory issue). All that matters is that the PCV valve is connected to the crankcase volume somehow.
Old Jan 9, 2013 | 06:53 PM
Thank you for every reply. My Point is, i need Oil vapor to coat valve for long life of valve.
Old Jan 9, 2013 | 09:23 PM
Inquisitive Old Guy's Avatar
Sawadee Kup -
There is still more than adequate oil vapor in the valve train area as well as normal oil splash to lubricate the valve stems. The positive crankase ventilization valve is just part of a long ago implemented process of controlling the vapors from going straight to the atmosphere here in the USA.
In case you ask - Long ago way north out of Udorn Thani and NKP too.
Sawadee Kup -
Cob Ku Ma
IOG
Old Jan 9, 2013 | 10:43 PM
Originally Posted by Inquisitive Old Guy
Sawadee Kup -
Sawadee Kup -
Cob Ku Ma
IOG
OH! you can speak thai, thank you for you reply. now i just use cover Breathe
both side of valve cover not connect anything.
Old Jan 9, 2013 | 10:56 PM
GetDown's Avatar
Good post, had this happen first-hand.
denf221
Nov 11, 2014 01:13 PM
dynamic63
Apr 9, 2014 06:58 AM
miked
Nov 14, 2012 08:31 AM
saud74
Oct 15, 2010 01:39 PM
godson
Drivetrain/Differentials
Feb 8, 2009 09:49 PM
