66 442 trunk trim resto
Old Mar 18, 2010 | 03:07 PM
halffast's Avatar
Member
I'm working on the trunk trim on my 66 442. The black paint around the letters has worn off. Does anyone know what paint is a good match to the original black?
Thanks in advance.
Old Mar 18, 2010 | 03:46 PM
Run to Rund's Avatar
semi gloss black from a rattle can works fine. Wipe it off the surfaces of the letters before it dries.
Old Mar 18, 2010 | 05:17 PM
halffast's Avatar
Member
Perfect! Thank you
Old Mar 18, 2010 | 05:33 PM
4-Speed's Avatar
Mark can I call you? I have a great process for the trim resto-
Dave
Old Mar 18, 2010 | 05:34 PM
Hairy Olds's Avatar
Shoveling Snow
Use SEM trim black #39143 it has some acid in the paint that will etch the chrome so the paint will stick.
Old Mar 18, 2010 | 06:11 PM
halffast's Avatar
Member
Dave
Thanks Dave, I'll PM my number to you
Old Mar 18, 2010 | 06:14 PM
halffast's Avatar
Member
Thanks Hairy Olds -I had some concerns about the paint sticking without some type of etching. I'll check out the SEM.
Old Mar 19, 2010 | 08:27 AM
todd66442's Avatar
I'll have to try that paint for my 66. I bought a bunch of Krylon's Satin black and have always thought it was a great match for many areas that needed freshening up.
Old Mar 22, 2010 | 04:54 PM
bummerino's Avatar
wow, answered my question too! Thanks. Has anyone had any experiences repairing the back trim. Mine has a small crack in it, I intend to stop drill it, then attempt a repair using epoxy. I'll use the smallest drill bit when I stop drill it. Hope it can be repaired. except for the small crack it's pretty cherry.
Old Mar 25, 2011 | 11:01 PM
halffast's Avatar
Member
Finally painted my trunk trim panel and I thought I would post some pictures. They're not the best but they'll give you a general idea of how it turned out. I used the SEM trim black #39143 as suggested above. I applied vaseline to the faces of the letters and the paint wiped off easily - pretty slick. I'm very happy with the results. - Mark
Beob
Dec 30, 2020 08:22 AM
shamusj
Apr 7, 2018 08:10 AM
K-Dog
Apr 11, 2015 07:09 AM
maxxer442
Jan 20, 2010 10:58 AM
agtw31
Jan 23, 2008 11:41 AM
