66 442 trunk trim resto
I'm working on the trunk trim on my 66 442. The black paint around the letters has worn off. Does anyone know what paint is a good match to the original black?
Thanks in advance.
Thanks in advance.
wow, answered my question too! Thanks. Has anyone had any experiences repairing the back trim. Mine has a small crack in it, I intend to stop drill it, then attempt a repair using epoxy. I'll use the smallest drill bit when I stop drill it. Hope it can be repaired. except for the small crack it's pretty cherry.
Finally painted my trunk trim panel and I thought I would post some pictures. They're not the best but they'll give you a general idea of how it turned out. I used the SEM trim black #39143 as suggested above. I applied vaseline to the faces of the letters and the paint wiped off easily - pretty slick. I'm very happy with the results. - Mark
shamusj
Apr 7, 2018 08:10 AM
