68 442 w30
Old January 24th, 2018, 11:05 AM
Joevite12's Avatar
68 442 w30
I am bringing an all orignal 4 speed w30 back to former glory and am in need of radiator baffle and shroud having hard time finding original tunnel type 2 piece part any help would be appreciated
Joevite12 is offline
Old January 24th, 2018, 01:56 PM
72 Olds CS
RetroRanger's Avatar
I know what a 68 442 w30 is but i dont know what these parts are ?
radiator baffle .... original tunnel type 2 piece part
any pics or manual diagrams to help the search along ?
RetroRanger is offline
Old January 24th, 2018, 03:01 PM
Joevite12's Avatar
68 w30 radiator
Baffle is top piece that mounts rad in place 2 piece shroud is about 6 inch tunnel around fan baffle has has a semi hump on top
Old January 24th, 2018, 03:05 PM
Joevite12's Avatar
not sure how to attach image but can see on google image of 68 w30 engines
Old January 24th, 2018, 03:53 PM
442Harv's Avatar
Do you mean the radiator top plate? That goes over the top of the radiator, and holds it in place? The metal piece? Also the other piece do you mean plastic fan shroud?
442Harv is offline
Old January 24th, 2018, 04:19 PM
Joevite12's Avatar
yes
Old January 25th, 2018, 06:41 AM
442Harv's Avatar
I see them on Ebay, also Olds vendors all sell them Parts Place seems like a good price, Thy should also have the shroud.
442Harv is offline
Old January 25th, 2018, 06:53 AM
Joevite12's Avatar
thank you but ive looked at all the all places mentioned but do not have orinal looking top with hump also the piece that mounts on shroud where rad hose clamps is not shown probably have to call place like opgi and try to explain to tech in detail what i need
Old January 25th, 2018, 08:42 AM
Good luck with that...
Most of these repro places are hard pressed to provide accurate technical info for popular cars like Chevelles. Their knowledge of Oldsmobiles, especially rare parts on rare Oldsmobiles, is lacking at best.
I guess I'm still not sure exactly what part you are asking about. Is this the metal top plate for the radiator or the plastic fan shroud? I've got a 1968 W-30, and neither of those is "two piece". No this photo is not my car. This one appears to have an incorrect disc brake metering valve (with a drum brake M/C) and repro red inner fenders).
joe_padavano is offline
Old January 25th, 2018, 09:02 AM
Joevite12's Avatar
i need both metal top plate (in photo where rad hose is clamped)and shroud my mistake from photos i have seen looked like 2 piece again thanx for info
Old January 25th, 2018, 09:13 AM
Kevin W's Avatar
I'm in the process of restoring a 68 442 W30 4 speed cars as well. The 4 speed cars shouldn't get the plastic fan shroud, just the auto did.
Here is a thread that discussed this:
https://classicoldsmobile.com/forums...an-shroud.html
There are a couple different version of the rad top plate for 68, here another thread that discussed it as well:
https://classicoldsmobile.com/forums...questions.html
I hope this helps.
Kevin W is offline
Rocketdriver
June 6th, 2019 05:01 PM
RickDuden
January 7th, 2018 01:34 PM
70-442-W30
July 30th, 2016 04:27 PM
halfmoontrail
July 22nd, 2013 06:51 AM
Quick Reply: 68 442 w30
