68 442 w30
68 442 w30
I am bringing an all orignal 4 speed w30 back to former glory and am in need of radiator baffle and shroud having hard time finding original tunnel type 2 piece part any help would be appreciated
68 w30 radiator
Baffle is top piece that mounts rad in place 2 piece shroud is about 6 inch tunnel around fan baffle has has a semi hump on top
thank you but ive looked at all the all places mentioned but do not have orinal looking top with hump also the piece that mounts on shroud where rad hose clamps is not shown probably have to call place like opgi and try to explain to tech in detail what i need
Most of these repro places are hard pressed to provide accurate technical info for popular cars like Chevelles. Their knowledge of Oldsmobiles, especially rare parts on rare Oldsmobiles, is lacking at best.
I guess I'm still not sure exactly what part you are asking about. Is this the metal top plate for the radiator or the plastic fan shroud? I've got a 1968 W-30, and neither of those is "two piece". No this photo is not my car. This one appears to have an incorrect disc brake metering valve (with a drum brake M/C) and repro red inner fenders).
Good luck with that...
I'm in the process of restoring a 68 442 W30 4 speed cars as well. The 4 speed cars shouldn't get the plastic fan shroud, just the auto did.
Here is a thread that discussed this:
https://classicoldsmobile.com/forums...an-shroud.html
There are a couple different version of the rad top plate for 68, here another thread that discussed it as well:
https://classicoldsmobile.com/forums...questions.html
I hope this helps.
I hope this helps.
Rocketdriver
Jun 6, 2019 05:01 PM
virtualwsp
Mar 25, 2017 10:05 PM
halfmoontrail
Jul 22, 2013 06:51 AM
