Wheel/Tire set up. Will they clear?
I Have a 1969 442 and want to swap out the rear wheels and tires. I think I've done most of the math correct but want any opinions before I pull the trigger on the purchase. Here is the set up I want to use:
Wheels: 15x8, 5x4.75 bolt pattern, 4.25 backspace, -6 offset,
Tires: 275/60/15
My questions are two fold:
Will the wheels clear?
Will the tires rub?
If you feel the tires are oversized will 255/60/15 do the trick?
Thanks in advance
Tires: 275/60/15
Will the tires rub?
Thanks in advance
personally I like the 275-60 it fills the fenderwell up nice. Do you have a wheel you can try. I think I have used 4.5" backspace Welds before with that tire
Tires: 275/60/15
Will the tires rub?
Thanks in advance
Tires: 275/60/15
Will the tires rub?
Thanks in advance
Tires: 275/60/15
Will the tires rub?
Thanks in advance
Tires: 275/60/15
Will the tires rub?
Thanks in advance
Rear tires: SSII 15 x 8 (4.5 in backspacing), MT ET street drag radial P275/60/15
front: SSII 14x6, P245/60/14 BFG radial TA's
Del70
September 30th, 2014 07:21 PM
cutlassefi
November 28th, 2013 12:08 PM
auto_editor
July 10th, 2011 11:20 AM
