Wheel/Tire set up. Will they clear?
Old Nov 26, 2008 | 06:36 AM
4fortwo's Avatar
I Have a 1969 442 and want to swap out the rear wheels and tires. I think I've done most of the math correct but want any opinions before I pull the trigger on the purchase. Here is the set up I want to use:
Wheels: 15x8, 5x4.75 bolt pattern, 4.25 backspace, -6 offset,
Tires: 275/60/15
My questions are two fold:
Will the wheels clear?
Will the tires rub?
If you feel the tires are oversized will 255/60/15 do the trick?
Thanks in advance
Old Nov 26, 2008 | 07:06 AM
gearheads78's Avatar
car guy
personally I like the 275-60 it fills the fenderwell up nice. Do you have a wheel you can try. I think I have used 4.5" backspace Welds before with that tire
Tires: 275/60/15
Will the tires rub?
Thanks in advance
Old Nov 28, 2008 | 01:05 PM
raven1466's Avatar
Tires: 275/60/15
Will the tires rub?
Thanks in advance
I put the exact same specs for tires and rims on the rear of my 69 Cutlass S today and they fit just fine. No rubbing at all.
Old Nov 28, 2008 | 01:12 PM
raven1466's Avatar
Rear tires: SSII 15 x 8 (4.5 in backspacing), MT ET street drag radial P275/60/15
front: SSII 14x6, P245/60/14 BFG radial TA's
Old Nov 28, 2008 | 01:43 PM
4fortwo's Avatar
Thanks Raven. Assuming you've had no issues or did any mods, I'd say my question's answered.
442b
Wheels and Tires
Jul 3, 2020 10:02 AM
Del70
Sep 30, 2014 07:21 PM
cutlassefi
Nov 28, 2013 12:08 PM
auto_editor
Jul 10, 2011 11:20 AM
Want-A-Vert
Feb 3, 2007 11:23 AM
