What does it take to
get a OIA hood for a '69 Cutlass?
Can a '70 hood be converted?
We've a chopped and sectioned '69 Cutlass, [I'm trying to get pics, have some poloroids that're bad] that has 5" out of the sides, and the carb is so close to the hood, you can't even put the stud in it!!
Thought of the H/O scoop, but I think the OIA hood would give more room.
It's a 350, and wanted to put a 455 in it, but there's no room, heightwise!
Also thought about modifying the engine stands and front crossmember to drop it down more - don't think the pan can be modified.
Anyone have any suggestions?
The OAI hood won't provide any more clearance than stock, and if it has an air box underneath it will actually provide less. Note that the surface between the two scoops is at the same level as on a non-OAI hood, and that's the part directly over the carb. The H/O scoop is a better choice.
costpenn
August 29th, 2018 11:42 AM
Xavier777
January 27th, 2013 08:19 AM
oldsmoboogie
September 24th, 2012 01:04 AM
Flye
April 29th, 2009 10:39 AM
