How much power does it take?
Im curious as in how much hp and tq it takes to run a givin time. For example how much power to run a 13 to 13.5,12.5 to 13,12 to 12.5 etc. If you could post up some docmented power numbers and ets it woud be appreciated. I know hp to weight ratio and traction are limiting factors thats why i have .5 sec variable. Im just curious if im in the ball park to break into the 11s? Thanks for your input
Thanks 380racer that is a great link. Copper i do have an h pipe with a madrel bent 2.5 inch duel flomaster kit. I am running a built 2004r trans with a 3000 stall non lock up 10 in converter add 3.73 gears in a 12 bolt
Ahhh gotcha. Adding cut outs can give you a tenth or two aswell. I know if I run my exhaust through the muffler I run a tenth slower if I unbolt the mufflers and run the open x pipe it runs a tenth quicker.
Thanks for the added info on your combo. I am a believer in getting quicker without adding a ton more horsepower. For example, in my C Head days I saw gains with Tire and suspension upgrades. What do your 60' times and 1/8 mile ET and MPH look like? And there is always the everpopular " Cars on Diets go Quicker" approach...don't overlook weight savings even in a street car.
12.5's are Dang fast for a driver You're on the right approach!!
Danny
Danny
Im running a 275/60 bfg drag radial, my 60' times are usually 1.8ish wich i feel is pretty lazy is a 1.6 60' time outta the question for a street car on drag radials? I have edebrock adj uppers and boxed lowers with pinion angle set at about -2 degrees. My 1/8 mile times are 8.0 sec and i run 105 mph at the top. I have a msd billit dist. with no vaccume adv canister and a msd box. What should i be looking for in timing initial? total? and all in by what rpm? I have a 770 street avenger carb stock out of the box with the lightst spring. The motor is a .30 over 455 with 9.5compression and forged pistions, the heads have been ported and larger intake valves installed by a reputable olds builder,the cam is a comp cam pt no. cca-sk42-225-4 i will have to look up the specs as i cant find the card
Cam pecs are intake dur at .050 240, exhaust dur at .050 246, intake lift 541, exhaust ift 544 on a 110 lobe seperation is this too much cam? I have entertained going with a solid cam down the road but id like to get the most outof this combo first.
Sorry if I missed this earlier,. but what Intake Manifold? Also how do you launch the car? I found my old combination was quicker from just off idle...as in 900 rpm +-...If I brought the car up against the Converter, I would lose as much as .12 sec. The car seemed to like the " shock " to the suspension for best 60' and ET. I assume 18 to 19 psi in the Drag Radials? That has worked best for me.
With that cam, I would run as much initial timing as the car will crank with and total of 34-35 and all in by around 3000. Run decent fuel and listen for pinging.
Just some thoughts.
Danny
Just some thoughts.
Danny
I have a torker intake and i run about 22 pounds in the rear. It did seem to run better off idle when i would leave at 2000 rpm it would just spin like crazy. I just switched to a 4 inch wide front wheel to take some weight off the front as i have a pic and im very close to pulling the drivers side front. I am thinking about trying and adjustable rear bar that bolts to the frame and not the controll arms also. Do you think i have enough carb? NO i dont race in any class just for bragging rights i have a friend with a 68 camaro that runs 11.70 and a nother friend with a 68 firebird that runs 11.60 so i want to keep up and let the driver be the deciding factor here.
I run the same size Drag Radial as you do just in the M/T brand. I have gone 10.28 with a 1.40 60' running 18 psi. You may want to try that lower pressure. 770 cfm is plenty, I ran 11.40's with 750 Q-jet and Performer Intake. Quicken up the Advance, look carefully at your carb jetting...get some more weight out of the car...the front Wheels were a good move. I know you will lose some street manners, but a more race oriented Torque Conv. may help, closer to 3700, but check with some of the top manufacturers.
Good luck and have fun
Danny
Danny
I have never seen any BFG dragradial car have great 60ft times except in cars running in classes that were required to run them. The suspension has to be 100% spot on to get them to hook. First chance you get switch to M/T dr's at 18/19 psi and watch your 60ft go down.
Here's a pretty simple tool that can help you to get a good idea-
http://www.richmondgear.com/112901.html
Oldsmoboogie, I think you should be able to go 11's with that combination. I think you just need to get it tuned in. I also agree with others in that the M/T drag radials are far better than the BFG's. I run a similar combo to you and have gone 11.67 @ 114mph. My combo is as follows:
461 CID
10.25:1
ported A heads
Torker intake
Holley 850 DP
1-7/8 x 3 headers
3" exhaust
10" 3200 stall
3.73 gears
275-60 MT drag radials
3825lbs. w/driver
best 60'= 1.60
best 1/4= 11.67 @ 114.6mph
461 CID
10.25:1
ported A heads
Torker intake
Holley 850 DP
1-7/8 x 3 headers
3" exhaust
10" 3200 stall
3.73 gears
3825lbs. w/driver
best 60'= 1.60
461 CID
10.25:1
ported A heads
Torker intake
Holley 850 DP
1-7/8 x 3 headers
3" exhaust
10" 3200 stall
3.73 gears
3825lbs. w/driver
best 60'= 1.60
461 CID
10.25:1
ported A heads
Torker intake
Holley 850 DP
1-7/8 x 3 headers
3" exhaust
10" 3200 stall
3.73 gears
3825lbs. w/driver
best 60'= 1.60
461 CID
10.25:1
ported A heads
Torker intake
Holley 850 DP
1-7/8 x 3 headers
3" exhaust
10" 3200 stall
3.73 gears
3825lbs. w/driver
best 60'= 1.60
461 CID
10.25:1
ported A heads
Torker intake
Holley 850 DP
1-7/8 x 3 headers
3" exhaust
10" 3200 stall
3.73 gears
3825lbs. w/driver
best 60'= 1.60
I run 93 octane pump gas and 22 initial and 35 total timing all in by 2200 rpm. I also run an adjustable vacuum advance but it's set to advance very little. Some say you can't run that much compression with iron heads on pump gas but I disagree DEPENDING on the rest of your combination. Cam timing, quench, carb tune, converter stall, gear ratio, weight, etc. all are factors.
Never dyno'd but according to the calculator 380 Racer posted it's about 475hp. I figure it's probably closer to 500hp seing as it's not optimized for the dragstrip as the gearing and converter are a compromise to make it more street friendly. I'm confident it would go 11.40's with more gear and converter.
Thanks Chad. The reason I ask.. Local shop told me that there is no way I can run 10.25:1 with iron heads. We used to have 93 octane pump here, but now only 91. This is in a 10.25:1 Toro motor. I haven't measured the piston dish yet, but I think it will be less than 10:1 with a .040" head gasket. I know what I'm getting into. This is a junkyard motor that cost me nothing. My only investment is gaskets, crank polish, bearings, rings, hone, cleaning, and time. I'll keep it under 5000 rpm, and we'll see how long it lasts.
My 12.11 is with 3.42 gears and a really REALLY stiff suspension (big block springs, Hellwig 1 1/4" sway bar, etc.) I am working a deal right now to get Moroso trick springs and QA1 adjustable shocks up front, and I'm going to trade the Hellwig over to my convertible and put the stock sway bar back on the silver car. Hopefully that will put me in 11.70 range and then I'll trade the gears out for 3.90's to get even lower.
I'm interested in your suspension, you're obviously running well for less HP than I have. Not saying I wanna copy you, but it might not be a bad idea
My suspension:
FRONT
stock upper and lower A arms
Moog 6204 springs (6cyl Tempest)
90/10 shocks
no sway bar
REAR
UMI adjustable uppers
UMI boxed lowers
stock sway bar
air bags at 6lbs/16lbs
stock springs
poly bushings
I launch at 1200 rpm and shift at 5200/5400 rpm
FRONT
90/10 shocks
no sway bar
REAR
UMI boxed lowers
stock sway bar
stock springs
poly bushings
#31
#33
I went to the track last night but got only 2 passes in the best being a 12.25 at 108.5 and a 1.7 60ft. I switched to an 850 street hp and a 1 inch open spacer. I havnt had a chance to mess with any tuning yet as the track was very busy. The bop race at cordova is in 2 weeks so i should have a chance to get some runs in and start tuning. And it doesnt hurt that there will be a ton of olds guys there for me to ask for advice!
#34
#35
#36
#37
As far as I know, the MPH a car ran at a given weight has allways been the determining true HP on that given day, at that moment, in those conditions, from my testing it seems about every tenth of barometer gain is about 7 HP on a 700 HP engine. I will take high RPM HP over TQ every day of the week, when it comes to putting a car down a dragstrip.
#38
I have to use adjusted altitude which takes into account the barometer, plus temp, humidity, dew point and water grains. We race in 2600-3000 foot of adj altitude which affects both.
With us not running it all out I figure we are using about 650 HP out of the 730 it produced on the dyno. From what I have been told the SuperFlow 902 corrects to sea level and that's what I go by.
#39
Xavier777
January 27th, 2013 08:19 AM
Flye
November 25th, 2012 03:49 PM
Flye
April 29th, 2009 10:39 AM
