motor mount issue
motor mount issue
Anybody out there have a pic of the correct frame to motor mounts for a '68 442? I have a set sent to me by a guy who said they came off of a 1968 442 convertible and a set from olds parts. They couldn't be more different. I put the oem ones on with NAPA 602 1119 motor mounts to the block and they will not fit. This number is the same number listed on Fusicks site. Any help is appreciated.
1968 442s use the same frame pads and motor mounts for 350, 400, and 455. I'm sure you got the so-called "big block" mounts, which are NOT correct for 1968. Nearly every vendor gets this wrong. You want Anchor 2261 mounts (or dimensionally equivalent) if you have the original frame pads,
https://classicoldsmobile.com/forums...on-list-33826/
I'm am impressed as usual by you guys. I was sold the two tab mounts by NAPA. Looked up the part you recommended Joe and as usual, you where right they look like different ones than I have. I Have the type two from your photos Joe. I also have the type ones from your photos that I bought from olds parts. I think I have a good part number for NAPA I'll see what I can do with that tomorrow. Thanks again
I would like to thank you for your motor mount explanation was very helpful years ago I removed the 350 and installed a 455 some 20 years ago I must have used the motor mounts off the 350 since rebuilding my 455 I replaced the motor mounts the old ones were cracked I bought the ones for the 455 the 2328 part number was wondering why they wont work so I am now buying the 2261 hopping for a good result again thanks for spreading your knowledge
