Fan question...
Old Oct 14, 2024 | 06:29 AM
Tancuda's Avatar
Fan question...
Hi, do you think a 4 blade fan from a 70 delta 350 is about the same as a 71 442 that is part number 405443 ?
Old Oct 14, 2024 | 08:20 AM
69CSHC's Avatar
Tancuda, I'm not sure about that.
But I wouldn't use a 4 blade on a 455.
My first car a 67 Cutlass with a 330, came 4 blade no shroud and always ran hot. Was a 42,000 mile babied car prior to me.
I would think something like this below is a better idea.
Of note, my 69 350 came 7 blade clutch and shroud.
Old Oct 14, 2024 | 10:29 AM
The 1970 full size cars used a four blade fan that is 19.5" in diameter (P/N 405443). The 1971 A-body cars used a four blade fan that is 19.0" in diameter (P/N 405442). Interestingly, the 1970 A-body cars used the larger 405443 fan, same as the full size cars.
Old Oct 14, 2024 | 01:51 PM
Tancuda's Avatar
Thanks for the advice,....From what I see in the manuel, my stock set up for Non AC or HD cooling package is suppose to be with the 4 blade fan, I have pulley KN and KJ that is correct for a 71 455 no ac and power steering.
So I don't see a problem running a 4 blade fan with a good radiator no ?
If I want the stock 6 blade fan setup, I need 2 pulley (for the good ratio), also a pulley for the power steering, probably a water pump (not sure if it's 5.5" or 6" for AC) a shroud, the correct radiator top plate, so pretty big job $$.
I want the stock setup but if there's really a risk of overheating then I'll probably change my mind..
Tancuda
Sep 2, 2024 05:03 PM
Tancuda
Jun 29, 2024 09:06 AM
wherlehy
Dec 3, 2023 05:49 AM
Bee Saint Louis
May 2, 2022 06:36 PM
costpenn
Nov 12, 2015 09:07 PM
