Efi
Old Jan 12, 2026 | 05:51 PM
2oldsguy's Avatar
Efi
I am in the process of installing ACES EFI on my 70 442.It is a slow go as I am also working on a 70 Corvette LT1 that I recently acquired that sat for over 29 Years.
I have the stock 455 low rise aluminum manifold and the OAI, so I would like to keep that. The issue is the Q-Jet to square bore normally requires a 3/4" adapter. I had in stock a 1/4" phenolic spacer for the Q-Jet and the Aces EFI has both bolt patterns. I didn't like the sharp edge on the intake so today I rounded them over to create a smooth transition. I also used the original throttle cable bracket and modified it and raised it up to the higher pivot position on the throttle plate..
I also had to machine a pin to attach the cable at the throttle plate.
Old Jan 13, 2026 | 02:41 AM
fleming442's Avatar
I'm sorry.
Old Jan 13, 2026 | 02:58 AM
Does it fit with the OAI hood now?
Old Jan 13, 2026 | 05:32 AM
dc2x4drvr's Avatar
I used a 4 hole base gasket after trying the one you’re using, better fuel distribution. Here’s a shot of my fuel line setup.
Old Jan 13, 2026 | 05:47 AM
2oldsguy's Avatar
Is that an original Q-Jet intake?
Old Jan 15, 2026 | 07:44 AM
dc2x4drvr's Avatar
Edelbrock 04B, with a lot of plenum work, and port matching..
orpp50
May 1, 2024 03:28 AM
brotherGood
Jan 6, 2023 09:31 AM
YellowCutlass
Feb 27, 2022 01:00 PM
72455
Jun 16, 2021 04:34 PM
BrawnyMan
May 4, 2020 04:52 AM
