Driveshaft / yoke orientation?
Old May 28, 2014 | 03:23 AM
tkw31's Avatar
Getting ready to put u-joints in my driveshaft for a '70 442 & was wondering if this is the correct orientation front or back on the driveshaft. I can't remember if the yoke goes on the short or long narrowed end. I've attached a photo to show what I'm talking about. Thanks.
File Type: gif
Old May 28, 2014 | 06:37 AM
442Harv's Avatar
That photo is correct.
Old May 30, 2014 | 03:15 AM
Yellowstatue's Avatar
When you install the u-joints, have the grease fittings in the same orientation. Makes it easier to grease when installed in the vehicle.
Old May 30, 2014 | 07:13 AM
More importantly, when you install the u-joints, be sure the grease fitting holes are in compression when moving forward, not tension.
Old Jun 4, 2014 | 03:56 AM
tkw31's Avatar
Thanks everyone....
Old Jun 17, 2024 | 12:15 PM
Newcurt's Avatar
U-Joint Compression v Tension
I’m installing a rear U joint on 1969 442. What/how is compression or tension?
Old Jun 17, 2024 | 02:30 PM
JohnnyBs68S's Avatar
As the driveshaft turns to propel the car forward, the "V" where the grease fitting is located (if the U-joint is equipped) should be under compression rather than in tension. This reduces the likelihood of cracking the U-joint under abnormal stresses like when launching the car on a drag strip w/ sticky tires..
hackmansr
Oct 1, 2014 08:36 AM
miko442
Jul 9, 2013 06:11 PM
oldzy
Mar 15, 2011 10:29 AM
scubastever
Jan 13, 2010 09:21 AM
