1971 442 W30 questions
Old Aug 18, 2024 | 11:08 PM
  #121
Kingdiamond69's Avatar
https://promaxxtool.com/products/pow...ords&utm_term=
Old Aug 19, 2024 | 05:29 AM
  #122
"If" it is broken, there's a possibility you can use a very long decking screw or a extra long lag construction wood screw to insert into the broken tube, a couple turns on the screw & extract the tube. Fingers crossed. Good Luck.
Old Sep 9, 2024 | 06:46 PM
  #123
68post's Avatar
Nice find!! Are you changing color, or what is the original color? Should be a real looker once you're finished.
Any updates?
Old Sep 9, 2024 | 06:55 PM
  #124
68post's Avatar
Do you know that the three spoke steering wheels were on 1969 and older and '70 and up used 4 spoke steering wheels? (in the spirit of correctness)
Old Sep 9, 2024 | 06:56 PM
  #125
Originally Posted by Kingdiamond69
Yeah once I saw that I was sold I have not done anything with the motor yet waiting on my new ignition to get here but it has a holly double pumper on it so I think this guy might have been taking this car to the local drag strip so it might have a beefed up 455 in it.
Regarding that Chevy 12 bolt rearend, it reminded me that back in the 80s a local guy had a 1970 W-30 4 speed that he regularly tracked and broke the carrier on the original O-Type 3.91 rearend, so he swapped in a Chevy 12 bolt. Prolly a similar situation with your drag car.
Old Sep 9, 2024 | 08:34 PM
  #126
Any updates?
Original paint code was black going with a black gold color scheme on the rebuild with a scooped glass hood.
Updates are trunk pan is replaced floor pan on drivers side replaced passenger side had a few spots that we patched getting ready to do some patch work on the inner fenderwells in the passenger rear install a new trunk dropoff.
Took the rear bumper off today to do some metal fabrication installing the dual cutoff 442 bumper once its repainted.
Got the interior order from legendary interiors looking for a good dash to replace the worn dashpad it currently has.
And no I was unaware of the period correct steering wheel but this one isc already installed so ill just stick with that .
Old Sep 10, 2024 | 04:37 AM
  #127
69HO43's Avatar
Just glancing at this thread, you're still going to either need to replace the core support or repair the area(s) that someone cut up. Because there's a single screw holding the center portion of the plastic grille center section on 71/72 that goes right at the tip. Without it, it'll have a tendency to flop around.
Old Sep 10, 2024 | 09:37 AM
  #128
I had the former body shop manager of the Monroe Olds shop come look at this car in person this is a 71 442 with 70 fenders hood and grills the core support is a 71 core support we confirmed this earlier in the thread do you honestly think I would leave the front end looking like that?
Outside of surface rust there is nothing wrong or date incorrect with the core support itself new glass hood new grills new new Fenders are all being ordered.
Old Sep 11, 2024 | 11:49 AM
  #129
70W-32's Avatar
Looks like the passenger front floor has been replaced with a giant piece of sheet metal
Old Sep 11, 2024 | 01:05 PM
  #130
Nope original floor but it had some rust spots so we patched those up drivers side got a full pan replaced.
jensenracing77
Nov 17, 2022 02:31 AM
GbodyMane
Sep 23, 2020 08:07 AM
Rams442
May 25, 2020 06:54 AM
dhwhite43
Sep 2, 2018 11:26 AM
