1969 442: OAI w/Air Conditioning?
By the same token the factory literature is NEVER in question is it
Doesn't the factory literature say you couldn't get a 69 W30 with disc brakes? The friend I mentioned in my first post had a 69 W-30 for 15 years and it did have factory manual discs. It's a strange world, things happen.
Below is a pic of how the RH tube looks from the side on my 68 without the RH clamp attached. Again, nothing rubs on the tube that causes any wear - it kind of floats above everything.
https://classicoldsmobile.com/forums...y-jm-68-ho.jpg
"The reason that A/C was not factory-available on the 1968-69 O.A.I. cars was due to the interference between the A/C compressor and the O.A.I. flex hose. The only [bumper scoop] 68-69 O.A.I. cars that... came with A/C were the 1968 Hurst/Olds. As noted above, the compressor rubs on the hose and kinks it."
Oh, so, rubbing and kinking the hose was OK for the H/O, but not for the lowly W30 442.
That explains it.
That explains it.
Timmy1966_442
Sep 30, 2013 10:58 AM
