1966 442 with 69 455 - adding Air Conditioning
Old September 30th, 2013, 09:50 AM
Timmy1966_442's Avatar
Good morning all,
I am looking to add a "factory" or at least factory appearance air conditioning system. Has anyone done this project? Degree of difficulty?
I would be interested in an aftermarket kit if I could use the correct interior vents.
Another caveat to the project is the motor a newer 455 so a complete original kit may not work.
Timmy1966_442 is offline
Old September 30th, 2013, 10:30 AM
tmaleck's Avatar
Originally Posted by Timmy1966_442
Good morning all,
I just posted a long winded summary of my experience of doing something very similar. My 67 had factory air, so that is a bit different, but you may find some of it helpful. The Vintage Air compressor and bracket kit fit 330-455, so no worries there.. BTW, the V.A. kit is probably 40-50 pounds lighter than stock.
Tim
tmaleck is offline
Old September 30th, 2013, 10:38 AM
Thank you Tim, that is good info.
Did you order a custom kit for VA? I didn't see a 66-67 kit available.
Also, were you able to use factory style vents and locations?
Old September 30th, 2013, 10:58 AM
tmaleck's Avatar
Vintage Air does not offer on 'official' kit. I knew the Chevelle has the same firewall as a Cutlass, so I started there. I did a lot of research and reading before making the call, but it worked out OK. I did use factory dash vents for the outer locations, I made one to replace the center vent, as mine was broken. My car had factory air, so the vents were already there for me to use. I chose the Gen IV custom kit, it is all electronic control and the latest tech they offer. I'm not so thrilled with the universal kit, but you might find it a viable option, since you won't have the massive firewall hole to block off like I did. You may also be able to start with a Chevelle non-factory air kit and then just mod your dash for the ball vents. The center vent is just a plastic block off in the dash and easily replaced with a vent.
Tim
tmaleck is offline
Jonb442
October 4th, 2014 08:23 AM
spacecowboy
September 9th, 2013 09:24 AM
DocOlds
February 21st, 2013 02:25 PM
PalmSpringsOlds
July 17th, 2012 09:22 AM
rand5204
April 10th, 2012 06:37 AM
Quick Reply: 1966 442 with 69 455 - adding Air Conditioning
