RPM performer hood clearance '71
I want to run a RPM performer in my 1971 Cutlass but I want to make sure I got 6.5 inch clearance from the top of the intake to the hood.
I know that some of you guys run stock air filterhousings on top of there RPM's but I need to know that I got 6.5 inch clearance....
please let me know. Many thanks, Ramon
I run the rpm a half inch spacer A NON drop based air cleaner with a 3 inch open element air fileter and the wing nut just scrapes the hood barely. The drop base will significantly add clearance. I think the stock air cleaner hangs down a bit more that the typical open element bases but you will need an adapter on a holley.
Tony72Cutlass'S'
July 12th, 2011 05:29 AM
