New Distributor for 1970 cutlass 350, recomendations?
Unless your old distributor has some issues, a new one won't increase performance.
I had an original points distributor set up with quality points, cap, rotor, recurve kit, and an aftermarket performance coil. It worked well to 6000 RPM. I swapped to a GM HEI distributor with quality cap, rotor, module, recurve kit, and a performance aftermarket coil. There was no absolutely difference in performance between the two.
If you truley have to replace yours, DO NOT BUY ONE OF THE CHINESE KNOCKOFFS, They do not fit the block and they wear out long before a good brand will. I would recommend a Pertronix, an MSD, Mallory, or any name brand. It might be more costly, but better value in the long run.
4 Barrels of Laughs
Location: I moved to pittsburgh so I can be near Primantis
an hei install (good luck finding used ones) will fire plugs in oil and they dont break too often.
Otherwise I dont see the words 'cheap part' next to too many of the new alternatives out there today
... Unless you mean a different car than the one listed under your avatar.
63super88
February 19th, 2014 03:04 PM
craftsmen22
January 18th, 2009 02:41 PM
