Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
springs too soft in front for a sbc 350
Old July 1st, 2018, 09:07 AM
tonyhuntsberger's Avatar
I read a thread where the author had installed front springs from a 53 Bel Air to get a firmer ride, and possibly help out with the ride height being too low. I've got those problems with my car due to the builder swapping in the 350. Good install, but need stronger front springs. Anyway. i ordered the heavier springs (Moog 639. 53 bel air) and hope to get started on the install next weekend. I still haven't mastered posting pics, but will try to figure it out again.
tonyhuntsberger is offline
Old July 1st, 2018, 09:31 AM
72 Olds CS
RetroRanger's Avatar
HI tony
You didn't say what car you have , but moog has tons of springs for many olds applications BBO sbo 442. Etc
These replacement springs would be an exact fit for your model
RetroRanger is offline
Old July 1st, 2018, 01:12 PM
Phantom Phixer
Charlie Jones's Avatar
Here is a list of Moog coil springs by dimension . It may help you select the right springs .
https://www.moog-suspension-parts.co...il_springs.asp
Charlie Jones is online now
Old July 1st, 2018, 03:12 PM
soft springs
I have a 1963 f85 convertible. Seems like the parts availability is a little scarce for that year. I'll see what the Moog 639 springs look like, i could always ebay them if neccessary. The thread I referenced was on the classic olds forums, and they worked out well for the author. I like a comfortable ride, and supposedly the moogs are rated for about 600 more lbs. Hopefully it works out well.
Old July 1st, 2018, 05:05 PM
72 Olds CS
Your right I just checked rockauto and moog and could find no springs listed for your 63, is there something special about your springs?
IIRC another member recently put springs in his 63 cutlass I'll see if I can find the thread
Old July 1st, 2018, 05:18 PM
72 Olds CS
https://classicoldsmobile.com/forums...5-cutlass.html
This was the thread I was thinking of around post 26 he mentions new rear springs , but no PNs
Old July 1st, 2018, 10:24 PM
money saving tips for 61-63 f85's
This is the post I was thinking of. I couldn't remember where the thread was so I did a search and it came up. Hope it works.
Old July 1st, 2018, 10:30 PM
The thread was in "Other Oldsmobiles"
Old July 2nd, 2018, 06:21 AM
72 Olds CS
Ah ok
To post a link copy the adress bar at the top of the page (starts w www.classicoldsmobile.com.....) and paste it into your reply
https://classicoldsmobile.com/forums...1-63-f85s.html
Like that
Good luck w your f-85
Old July 2nd, 2018, 07:24 AM
Thanks, I'm not very computer wise, need to get better!
Old July 8th, 2018, 01:38 PM
soft springs
Completed the coil spring swap, much better. Also changed out the sway bar end links. For those with a heavier than stock motor, the moog 639 springs work well in a 1963 f85 convertible. While the car was up on the lift, we noticed that the drive shaft was about 1 1/4 " too long, and was pushing against the carrier bearing. Guess I'll have to shorten it. The guy who built it up to this point sold it too the person I bought it from, and he sat on it for a couple years, so it really hasn't had any of the shakedown driving it needs. A few teething issues, I guess.
442oldz71
April 28th, 2018 10:35 AM
olds68442
August 9th, 2015 03:50 PM
kbdecatur
Suspension & Handling
January 9th, 2013 03:16 PM
hvysupreme
April 11th, 2012 04:47 PM
Jannebill
June 27th, 2011 08:51 PM
Quick Reply: springs too soft in front for a sbc 350
