"How to put down Dynamat" - suggestions?
Old October 18th, 2011, 05:41 AM
skryla's Avatar
I purchased a 3'x33' roll of FatMat (DynaMat family) for $150 delivered.
What would be the best way to put this stuff down on the floor?
Any suggestions on the size(s) I should cut this into?
Do I need a heat gun to put it down properly?
Best way to do the interior firewall?
Best way to do the inside of the doors?
Any an all suggestions/comments/tips would be greatly appreciated!
skryla is offline
Old October 18th, 2011, 06:22 AM
garys 68's Avatar
When I put mine down, I learned quickly the most important lesson: Make sure the surface is absolutely dry!!!!!. Even a little condensation from running a propane heater affected its adhestion.
It molds and stretches pretty well with a small roller. I heated the roll up to about 100 degrees in the oven, that might have made it a little more flexible and sticky.
I had the whole interior out so I stripped out the firewall insulation and stuck it everywhere, then put new insulation over it. I also put it on the door face under the panels.
garys 68 is offline
Old October 18th, 2011, 06:33 AM
skryla's Avatar
Nice Job! I have the entire interior out with fresh paint everywhere.
What size sections did you cut it into?
What was the "process" you used?
Example: Cut a 3'x3' section, lay it out, cut to fit, roll in place to fit contours, then take the adhesive protector and stick in place?
skryla is offline
Old October 18th, 2011, 06:58 AM
garys 68's Avatar
I cut the pieces to the approximate size, as big as was practical to handle. Heated the sections. Peeled off the backing as I unrolled each section and worked it into all the contours with the roller they supplied. Then cut off any excess.
garys 68 is offline
Old October 18th, 2011, 07:05 AM
car guy
gearheads78's Avatar
When I did mine I just cut the major flattest sections and cut them and layed them out. Once those were cut I rolled them down one at a time and them went back and did the more contoured areas with scraps from what I had cut. I also used aluminum tape at each seam to keep from making a big mess scooting around inside the floor for the day.
gearheads78 is offline
Old October 18th, 2011, 07:08 AM
Lady72nRob71's Avatar
Here are some posts that may help you...
https://classicoldsmobile.com/forums...html#post60544
https://classicoldsmobile.com/forums...html#post63224
https://classicoldsmobile.com/forums...html#post64083
https://classicoldsmobile.com/forums...tml#post160519
Lady72nRob71 is offline
Old October 18th, 2011, 07:13 AM
car guy
I forgot to mention that important step. Make sure to only peel off the backing a few inches at a time. I made the mistake on my first piece of peeling off the whole thing thinking I could lay it down like I wanted. I ended up wasting a 1/4 of the sheet. The stuff sticks to itself VERY well.
Old October 18th, 2011, 07:30 AM
501Paratrooper's Avatar
x2 on really clean! Mine went on well over por15, I didn't need to heat Florida summer.
Save all the scraps, I had enough left over to do my package tray.
501Paratrooper is offline
Old October 18th, 2011, 07:53 AM
It also will pull POR15 up once it is stuck to it! Make sure it is the way you want it BEFORE pressing into place. If you mess up, stop and cut off the rest and re-lay that part.
I swore I would never ever mess with that stuff again, but I just might do a wagon when i get one...
Old October 18th, 2011, 08:10 AM
72 Olds CS
RetroRanger's Avatar
hey stan that seems like a really good price where did you get it ??
RetroRanger is offline
Old October 18th, 2011, 01:26 PM
skryla's Avatar
Bought it on FleBay. It was actually $159 delivered for the roll.
I am not endorsing it yet! I will start installing tonight.
http://www.ebay.com/itm/100-80-Mil-R...item2a0dd6c737
skryla is offline
Old October 18th, 2011, 01:27 PM
skryla's Avatar
Hey Rob, thanks for the instructions. You take pics like me! Are you a schoolteacher?
skryla is offline
Old October 18th, 2011, 06:55 PM
A-Body University!
Dynamat works great over the talkative students' mouths...
Old October 18th, 2011, 07:51 PM
skryla's Avatar
I finished the firewall and back to the front seats tonight. Rob, you are a twisted soul to get all the "Dynamat" logos going the same way. How the heck did you do that?!
skryla is offline
Old October 18th, 2011, 08:06 PM
I wonder about that, too.
You are certainly not the first one to have noticed that...
In fact someone else said I was twisted as well............
Old October 19th, 2011, 05:30 PM
mike's88's Avatar
Not busting on D-mat, but when I did my salon, I did a search on the bay and found Fatmat without the lettering, for about 1/2 the price and made by the same company. Lot quieter inside. The roll I bought was able to do the entire floor and behind the rear seat, covering the cardboard seperator going to the trunk.
mike's88 is offline
Old October 19th, 2011, 05:39 PM
Real life reviews to alternates to the D are much appreciated. I made a thread "Dynamat - worth it or a waste" long ago and was lorn to which way to go.
D is very expensive and would prefer fatso should I do this again.
Old October 20th, 2011, 06:44 AM
Tony
archeryshooter's Avatar
fat mat
I used fatmat also and seemed to be pretty good stuff and yes much less money heres some pics of it
archeryshooter is offline
Old October 20th, 2011, 06:56 AM
garys 68's Avatar
FYI, I used Fatmat based on price. Very happy with the results and no labels to keep in line
garys 68 is offline
Old October 20th, 2011, 08:39 AM
ati
ati's Avatar
i have done 2 vetts in "Dynamat worked well but did my olds in fire and ice roofing mat one roll did the car for 60 bucks
ati is offline
Old October 20th, 2011, 09:30 AM
Asphalt stuff will not work in hot climates - it will melt and smell horrible forever.
Old October 20th, 2011, 12:40 PM
ati
ati's Avatar
its not asphalt its rubber. sticky on one side plastic cover on the other all the body shops use it
ati is offline
Old October 20th, 2011, 06:58 PM
Well, that's different then! Will look into that when the next layout happens.
Old November 3rd, 2011, 09:17 AM
Registered car nut
nonhog's Avatar
I see alot of verts posting on this subject. Been wondering if its worth the effort due to noise from above. Will it quiet enough just from the floor/firewall?
nonhog is offline
Old November 3rd, 2011, 09:43 AM
delete
droptopron's Avatar
Did you lay the edges over each other or butt them up to each other? This is something i am very interested in doing to my convertible not for the noise but for the heat. is there a brand that is more effective at heat reduction?
droptopron is offline
Old November 3rd, 2011, 10:43 AM
you lay the pieces down and butt them together. If you overlap, there will be bumps.
Old November 4th, 2011, 05:56 AM
HWYSTR455's Avatar
Keep in mind that it doesn't have to be perfect to deaden sound. There can be slight gaps, etc, and it won't have a negative dramatic effect overall.
Also note that just because it have an aluminum foil cover, it's doesn't shield heat as much as you would think. There are other products though that specifically shield heat that you can use with the sound deadener. Dynamat has 'Dyna-liner', which is the heat barrier product. It is meant to be used over Dynamat.
HWYSTR455 is offline
Old November 4th, 2011, 05:58 AM
Agree 100%. I used the dynaliner over the extreme stuff and it seems to do well.
Old November 4th, 2011, 06:05 AM
garys 68's Avatar
For heat, I used Reflexit in the footwells of my 68 corvette. It made a huge difference. When I did the olds, I used fatmat for sound, followed by reflexit for heat. Then threw the factory sound deadener, carpet with jute insulation backing for heat.
Kind of overkill, but it's quiet and cool.
garys 68 is offline
Old November 4th, 2011, 08:51 AM
Where were you in '72?
boondocker's Avatar
Where do get this stuff ? Home Depot?
boondocker is offline
Lady72nRob71
April 6th, 2013 07:27 AM
boondocker
August 3rd, 2011 08:22 AM
81 regency
April 21st, 2011 06:18 PM
jay770
October 4th, 2010 08:38 AM
boehm
September 26th, 2009 09:54 AM
Quick Reply: "How to put down Dynamat" - suggestions?
