Dynamat vs Second Skin Damplifier Pro
I ripping out the old wiring and thought it would be a good idea to put in some sound deadening in my 71 cutty s. model. Any suggestions on which is better Dynamat vs Second Skin Damplifier Pro
I am in the middle of laying down Fatmat. I got the bulk pack. It is less expensive than Dynomat and is supposed to be as good or better.
I have a friend who is a VW guy, and his tuner/audiophile circle swears by the stuff.
I can tell you that there is a huge difference in sound if you drop the little green measuring tape on the Fatmat compared to the bare floor.
It is a lot of work. I got about 1/2 the floor pan done in about 3 hours. Measure small pieces and roll them out. It is okay to overalp some. DO NOT pull all the backing off at once, go in steps. once this stuff is down and set it will not come up. It will pull paint of the metal. If you use a hair dryer to heat it up it might come off. Every curve and bend in the floor will need a cut in the mat so you can roll it flat. Then just place a small patch down. I was doing mine by doing larger ares first and then filling the voids later.
The kit for $130 has 100 sq feet, wooden roller and knife i8n the box. Shipping on their web site is free. They may offer a discount if you order more. I think I have enough to do floor, doors, roof, rear shelf, trunk, and quarters for under $200 shipped.
http://www.fatmat.com/bulk/fatmat/100.html
Have fun. I think all this work will be worth it.
Adam
Adam
As long as you stay away from the asphalt-based self-adhesive stuff, you should be fine.
I used dynamat (650 to do most of the car), but I think the other rubber based stuff will work fine. It is a lot of work and will challenge your patience limit...
Adam
Nothing beats the time I applied roofing tar to the entire floor of a Skylark convertible, expecting it to dry in a week or so, only to discover that IT NEVER DRIES.
I coated the entire floor. VERY thoroughly.
It did quiet the car down a whole lot, but it made the cross-country drive a month later FAR more interesting than it needed to be. Everything that I ever placed in that car had a spot of black on it somewhere, and it wasn't dry even a year later.
I still think of that car every time I smell roofing tar.
Heat/Sound Deadener
I just ordered some of this it claims it will keep the heat out and also it is a good sound deadener.
http://www.lobucrod.com/
Anyone try it?
Anyone try it?
BROWNBREAD this stuff is awesome. It's now called B-Quiet Ultimate. Look at the specs on it. Its almost the same as dynamat at the fraction of the cost just go to google and type in b-quiet itll take you right to the sound deadner. I've used dynamat and b-quiet ultimate in my car.. there's really no difference in my opinion. B-quiet is way cheaper though, thats what ill buy from now on. 50 sq ft $130
Hey thanks for the responses. So what ya'll saying is pretty much dynamat or FatMat. I like the price of fatmat butI've heard some bad reviews on the smell. So I think I'll just get the dynamat and just do the floors and the trunk so I can run the wires. ah yeah does anyone know how to use flickr i made an account and put some pics on now what?
Getting Started
Ok I hope this work but here are a few pics. There not that great and I will take more pics when i pull it out the garage
http://www.flickr.com/photos/54362552@N07/sets/
Adam
I've got it in my 66 Delta and in a Galaxie that I'm building for a buddy. There's no odor that I've noticed. I've compared it side by side to dynamat and I really can't see any difference whatsoever. I did, however, notice a difference when I paid for it. A big difference.
I forget what it's called right now but I used the rubber based roofing seal on my '70 about a year ago. It's done a good job of quieting the card down and has stuck pretty good through the winter and summer. It needs to be replaced now, but that's due tot he fact that I drove it this whole year with no carpet so it's gotten worn around the edges. But that's about 10,000 miles of city driving with no carpet for protection. And I'm only out about $40 for the whole floor.
skryla
November 4th, 2011 08:51 AM
boehm
September 26th, 2009 09:54 AM
