Click Here
Input on 100 spoke wire wheels with hex nut(knock off style)
Old Aug 4, 2013 | 03:27 PM
bcf102's Avatar
Anyone have any good/bad input on buying a set of 100 spoke knock off style wire wheels with the hex nut??A guy has a used set for sale but have heard a lot of good and bad things about this style of rim.Would they be any good on a Dailey driver and the occasional long trip or just end up being a headache????
Old Aug 4, 2013 | 03:58 PM
brddg's Avatar
Knockoffs have a bad rep for a good reason. Only if I had a mid year vette with them stock would I keep them. And they sell a look alike knockoff that is much safer for those same cars.
Old Aug 4, 2013 | 04:03 PM
oldstata's Avatar
Justin
If you are talking the new low rider ones I ve had several sets over the years never had a problem but I re torqued every oil change (3000) miles
Old Aug 4, 2013 | 04:09 PM
bcf102's Avatar
Yeah they are the newer low rider style,just wondering about them having issues with coming loose,or being hard to balance and not being true,they have been curbed a few times!!any problems with spokes coming loose or air leaks??
bcf102's Avatar
He wants 250$ for a set of 4
Old Aug 4, 2013 | 04:14 PM
oldstata's Avatar
Justin
Depending on how bad curbed checked they are ? I ve only had one set of spoked wheels leak on me ,I just installed a tube and ran them
I prefer some tire stretch but not too much at the same time to much will cause bead too leak just a FYI
Balance issues I never had any that I can recall
I rotated every 3000 miles so I retourqed I don't recall them ever being loose ,except for one set but I think some one loosened it . my car had been broken into but I never checked the tires three days later a few studs broke this was not knock off style wheel .
It's been several yeas since I ran this style of wheel I kinda out grew them
bcf102's Avatar
Do you mean you re torque the hub or the outer nut?do you have to tighten the outer nut on a constant basis??
Old Aug 4, 2013 | 04:56 PM
bcf102's Avatar
Thanks for the info
Old Aug 4, 2013 | 04:57 PM
bcf102's Avatar
Thanks for the info
BangScreech4-4-2
Feb 25, 2015 11:18 AM
delta_88_germany
Non-Olds Engines
Sep 28, 2014 05:44 AM
delta_88_germany
Brakes/Hydraulic Systems
Nov 2, 2013 05:06 AM
805cut
May 25, 2012 03:30 PM
walkthwalk92
Jul 21, 2009 08:30 AM
