Year One - 17" Magnum Wheels for a '66
Has anyone tried the Year One 17x8 (CMW178BLKS) or 17x9 (CMW179BLKS) Magnum wheels on a '66 442/Cutlass? I suspect the 8" is needed for the front and 9" for the back. Thanks for any input or alternate magnum wheel suggestions.
Ray
Ray
17"
I saw your thread and I am thinking about doint the 8" all around on my 69 did you do it yet, I noticed they are now selling the wheels as each instead of a set they were $800 a set now $229 per wheel . If you put a set on I would like to hear how they worked out and what size tires you went with.
Year One 17" Magnum Wheels
I bought the wheels - 8" front and 9" rear - Year One split a set of 4 for no extra charge vs. 4 of the same size. I did a test fit of the rear wheel, but it is hard to judge tire size yet without any weight in the car (still a shell on a rolling frame). I want the tire large enough to nearly fill the wheel opening - it may require some reduction to the spring height. I'm open to suggestions for size.
Ray
Ray
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
