Click Here
Year One - 17" Magnum Wheels for a '66
Old Jan 22, 2013 | 02:03 PM
rspreen1's Avatar
rps442
Has anyone tried the Year One 17x8 (CMW178BLKS) or 17x9 (CMW179BLKS) Magnum wheels on a '66 442/Cutlass? I suspect the 8" is needed for the front and 9" for the back. Thanks for any input or alternate magnum wheel suggestions.
Ray
Old Jan 22, 2013 | 03:37 PM
gearheads78's Avatar
car guy
What is the back space offered and how much if any will the car be lowered?
Old Jan 22, 2013 | 04:19 PM
rspreen1's Avatar
rps442
5.125 for the 9 in and 4.5 for the 8 in. Car will not be lowered and it has 4 wheel discs.
Old Jan 22, 2013 | 06:50 PM
car guy
Should work pretty good then with the right tire.
Old Aug 29, 2013 | 07:53 PM
ramrod31's Avatar
17"
I saw your thread and I am thinking about doint the 8" all around on my 69 did you do it yet, I noticed they are now selling the wheels as each instead of a set they were $800 a set now $229 per wheel . If you put a set on I would like to hear how they worked out and what size tires you went with.
Old Aug 29, 2013 | 08:43 PM
rspreen1's Avatar
rps442
Year One 17" Magnum Wheels
I bought the wheels - 8" front and 9" rear - Year One split a set of 4 for no extra charge vs. 4 of the same size. I did a test fit of the rear wheel, but it is hard to judge tire size yet without any weight in the car (still a shell on a rolling frame). I want the tire large enough to nearly fill the wheel opening - it may require some reduction to the spring height. I'm open to suggestions for size.
Ray
Old Aug 31, 2013 | 04:27 PM
ramrod31's Avatar
17s
Thanks for the pics Ray I am going with the 8" rims all around They look awesome on your car ,good luck
Old Sep 2, 2013 | 12:56 PM
71 OLDS's Avatar
Great prices on those wheels. Do they allow enough room for big rotors? 13" for example?
Old Sep 3, 2013 | 09:18 PM
ramrod31's Avatar
17"
So the wheels are awesome what did you do to mount the center caps
Old Sep 4, 2013 | 07:24 PM
Mr Nick's Avatar
Great choice!!
johnspd22
May 21, 2014 05:24 AM
ramrod31
Wheels and Tires
Aug 18, 2013 06:07 PM
jeffsims
Aug 2, 2012 02:51 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
