Tire Size on 10"
Tire Size on 10"
Hey Guys I saw pictures of this 442 clone for sale and I have to say I love the look the steelies and poverty caps give this car.Couple of thoughts ; does any body know this car ?and can anybody tell me what size of a tire that looks like? I read that the rears are 15x10 " but it doesn't mention what b.s the rims have
I know Wheel Vintiques sells a 15x10 but only with 4.5 " b.s ,if those are 295/50/15 I beileve you need a 5.5" b.s to fit that tire in the wheelwell without it sticking out past the fender.This is the look I want to go with my car.Thanks
Pick the rim width to match the needs of the tire. For example, most prefer 8" on the 275-60-R15. BS will have to be exactly correct if the tire fills the wheel well. Marsh Racing Wheels can make whatever offset your need, and so can a few other places. Standard weight 15x10 wheels may weigh 34 lb!
My 72 has aluminum Weld wheels,but I have had stock 15" rally that were widened to 10",for another car.The most important thing is the backspace.It has to be 5.5" with a 10" rim,for it to fit under there correctly.
I have 17x11 wheels w/6" BS and 315 tires on my 72. The 70-72 Cutlass bodies have a lot of room. I have run several sets of 15x10 wheels over the last 20+ years and I always made sure the BS was 5.5" so I could fit 295-50 tires on my a body cars and it always looks great!
I haven't found any sites that offer a 15x10 with a b.s of 5.5 " in the steel rim to fit the GM
bolt pattern 5x4 3/4 ,only the Corvette Rally wheel .I don't want to get into the widening process ,just means more dollars.
I just have to decide what tire I'm going to go with first ,my rear tire is 27 in tall now and if I go to a 295 it'll be shorter and increase the rpm at 55mph but if I go with a 275 its 28"
tall which will reduce the rpm at 55 .OTOH i'm not sure if either tire really makes that much of a difference we're only talking about 100 rpm either way,but it will make a difference as to which width of a rim I use.
1968 Toronado
Wheels and Tires
October 11th, 2012 09:33 AM
coldfire
Wheels and Tires
March 16th, 2012 04:17 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
#1CutlassSupreme
January 4th, 2009 06:02 PM
