Click Here
Tire Size on 10"
Old Nov 29, 2012 | 08:00 PM
61reoldsman's Avatar
Tire Size on 10"
Hey Guys I saw pictures of this 442 clone for sale and I have to say I love the look the steelies and poverty caps give this car.Couple of thoughts ; does any body know this car ?and can anybody tell me what size of a tire that looks like? I read that the rears are 15x10 " but it doesn't mention what b.s the rims have
I know Wheel Vintiques sells a 15x10 but only with 4.5 " b.s ,if those are 295/50/15 I beileve you need a 5.5" b.s to fit that tire in the wheelwell without it sticking out past the fender.This is the look I want to go with my car.Thanks
Old Nov 30, 2012 | 07:11 AM
Run to Rund's Avatar
Pick the rim width to match the needs of the tire. For example, most prefer 8" on the 275-60-R15. BS will have to be exactly correct if the tire fills the wheel well. Marsh Racing Wheels can make whatever offset your need, and so can a few other places. Standard weight 15x10 wheels may weigh 34 lb!
Old Dec 1, 2012 | 03:23 PM
Hey thanks Ill have to have a look around for someone who runs that combo on their car
and ask about the optimum B.S to get the tires tucked in the wheel well
Old Dec 1, 2012 | 05:54 PM
A search will help as others have discussed the topic on this site. I can tell you about the 66 but not other years.
Old Dec 1, 2012 | 08:05 PM
507OLDS's Avatar
I run a 15x10,with 5.5" backspace,and the tire size is 325/50/15.That is the biggest tire you will fit under a 70-72 Cutlass/442,without any modifications.The 15x10 rim MUST have 5.5" backspace.
Old Dec 3, 2012 | 07:32 AM
Thanks Brian ,that tire is even bigger than I thought you could use on a A body.What kind of a rim did you use for that tire? Aluminum or steel ?
Old Dec 4, 2012 | 05:06 AM
507OLDS's Avatar
My 72 has aluminum Weld wheels,but I have had stock 15" rally that were widened to 10",for another car.The most important thing is the backspace.It has to be 5.5" with a 10" rim,for it to fit under there correctly.
Old Dec 22, 2012 | 11:20 PM
orange442's Avatar
I have 17x11 wheels w/6" BS and 315 tires on my 72. The 70-72 Cutlass bodies have a lot of room. I have run several sets of 15x10 wheels over the last 20+ years and I always made sure the BS was 5.5" so I could fit 295-50 tires on my a body cars and it always looks great!
Old Jan 4, 2013 | 12:33 PM
I haven't found any sites that offer a 15x10 with a b.s of 5.5 " in the steel rim to fit the GM
bolt pattern 5x4 3/4 ,only the Corvette Rally wheel .I don't want to get into the widening process ,just means more dollars.
Old Jan 4, 2013 | 02:40 PM
507OLDS's Avatar
The new SSI's from Wheel Vintiques can be ordered with different backingspacings and widths.
I put a set on the back of one of my previous cars.
Old Jan 4, 2013 | 05:52 PM
As I posted above:
www.mrt-wheels.com
can make what you need.
Old Jan 8, 2013 | 09:21 AM
I just have to decide what tire I'm going to go with first ,my rear tire is 27 in tall now and if I go to a 295 it'll be shorter and increase the rpm at 55mph but if I go with a 275 its 28"
tall which will reduce the rpm at 55 .OTOH i'm not sure if either tire really makes that much of a difference we're only talking about 100 rpm either way,but it will make a difference as to which width of a rim I use.
1968 Toronado
Wheels and Tires
Oct 11, 2012 09:33 AM
coldfire
Wheels and Tires
Mar 16, 2012 04:17 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
#1CutlassSupreme
Jan 4, 2009 06:02 PM
