Click Here
Tire question
Old Dec 21, 2018 | 07:53 AM
Frisbee_k9's Avatar
Tire question
I have currently have Front: P215/65 R15 Rear: P255 /60 R15
I’d like to change to rear P295/50
WIll this fit from seeing the pic? My 442 is in blue.
Old Dec 21, 2018 | 09:34 AM
Your 215/65 fronts are 26" in diameter. The 275/60 rears are 28" in diameter. The 295/50s are 26.6" in diameter and only about 3/4" wider than the 275s. Yes they will fit, but won't fill the rear wheel wells as much as the 275s.
Old Dec 21, 2018 | 10:03 AM
Frisbee_k9's Avatar
Thanks Joe!
Old Dec 21, 2018 | 10:51 AM
droptopron's Avatar
delete
Assuming you have at least 8" wide rims. Thats' the minimum recommended for a 296/50
Old Dec 21, 2018 | 11:06 AM
Eddie Hansen's Avatar
stock suspension?
I like the look of this set up !!! is that rear suspension stock? I was thinking of 255/60/15's on the rear of my 69, however if possible i'd like to go a little wider but I don't want any rubbing I had 295's way back when but used air shocks LOL.. I did put new moog cc501 cargo coils in, could I go to 275/60s?
Old Dec 21, 2018 | 11:38 AM
Joe, note that he has 255-60s on the back, not 275-60s.
As stated, be aware that you need a wider tire for 295-50s than you need for 255-60s.
Old Dec 21, 2018 | 11:45 AM
Frisbee_k9's Avatar
i don’t want to jack up the back with the suspension just want to make sure the stance looks like the brown’69 in the post pic I added.
Old Dec 21, 2018 | 11:47 AM
Ah, I misread that. Sorry. 255/60-15s are 27" tall, so the 295s would be only slightly shorter and about 1.5" wider. Definitely would want wider rims with those.
Old Dec 21, 2018 | 12:21 PM
Frisbee_k9's Avatar
Joe,
I’m glad you said that because I was worried the 15x8 were too thin to support the tire size. I’m going to pass on the new tire size..thanks for your input.
Guy
DewChugr
Wheels and Tires
Mar 17, 2019 03:54 PM
65oldsrocket
Wheels and Tires
27
Jul 1, 2018 12:49 PM
Johnnylindo
Jan 26, 2018 05:12 PM
Sicklyscott
Wheels and Tires
Jan 26, 2018 10:08 AM
Roger60
Wheels and Tires
May 4, 2017 10:25 AM
