Rally Wheel Question
I just looked at these on the Wheel Vintiques website. They have them in chrome (so you wouldn't need trim rings or bezels). Available in 15x7, 15x8 and 15x10 all with specified backspacing if you want to go large
Wheel Vintiques
Wheel Vintiques
Thanks for the info. I'm pondering my options, and this car sits higher in the back than I like. I was considering slightly lower but wider rear tires. If I get too wide on the tires the sidewalls will really pinch in. My fronts are 215 70 15. Not sure how wide I can go on the back with my rims. Maybe 265 60 15 would fit? Without the sidewalls going horizontal?
Just depends on the look you're after. Not a fan of horizontal spill out unless it's a track car. Also need to make sure your suspension isn't going to hit the wheel openings. Are you tubbing this?
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
The car is so high with really beefy suspension, and I think it looks odd with the height and thin rear tires. I went from rear 215/70/15 to 225/70/15 as one of my tires was a mismatch and leaked anyway. The look is not bad from the side, but sort of strange from behind.
Maybe it's all in my mind.
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
costpenn
December 28th, 2013 08:39 AM
buckeye_hunter
October 19th, 2008 09:50 AM
