Click Here
P275/50-15 tires
Old Mar 3, 2025 | 02:03 PM
Jimbo120's Avatar
P275/50-15 tires
Just a quick question for anybody who would know. Someone nearby me has 4 BF Goodrich P275/50-15 tires for sale mounted on 4 old style rounded spoke Cragar SS 15x8 wheels. Everything looks in really good shape. Anyone have any experience having this size tire and wheel combo on their 67 Cutlass/442? My stock OEM rally wheels are showing their age. Will they be rubbing on the fender wells? Or just look bad? I have P255/60-15's now on the rear with P235/60-15 in front.
Old Mar 3, 2025 | 02:26 PM
z11375ss's Avatar
Senior Moment Member
Make sure to check the build date on the tires. This is important as tires generally last about 8-10 years even if they are just sitting in a garage. Here's a video on how to check. I have no idea as to the rubbing issue. With the tires I mean.
dc2x4drvr's Avatar
Check the date codes. Probably fit the rear, won’t work on the front.
Old Mar 3, 2025 | 05:29 PM
Well, for starters, you didn't tell us what car you were planning to put them on. But then again, the only cars Olds made were 1968-72 A-body cars, so I ASSUME that's what you are asking about...
In any case, 275/50-15s are a Honda-sized 25.8" outside diameter. They will leave a LOT of daylight in the wheel wells. By comparison, your 255/60-15s are 27.05" in diameter. Even your 235/60-15s are taller at 26.10" OD.
Also, what is the offset on the wheels? I suspect that even with the tiny diameter, you will have clearance problems in the front. These wouldn't be my first choice for an A-body.
Old Mar 3, 2025 | 07:59 PM
BFG does not make a 275 50 15 tire. It's either a 295 50 or 275 60 15. Neither of which will work well up front.
Old Mar 4, 2025 | 11:49 AM
Jimbo120's Avatar
Old Mar 4, 2025 | 12:00 PM
They did up until recently
Old Mar 4, 2025 | 12:15 PM
Jimbo120's Avatar
I didn't check the date code, but I'm guessing if a deleted size, they may be too old anyway.
Old Mar 4, 2025 | 01:42 PM
Recently meaning before 2009?
Old Mar 4, 2025 | 05:16 PM
Hey, I consider any car made this century to be a "new" car.
Old Mar 4, 2025 | 08:57 PM
69CSHC's Avatar
I had 275 50 15s on the back of my 66 442 20 years back. As Joe P mentioned they are on the short side vs stock.
Luckily my ride had the traditional "Oldsmobile that looks like it has a spare engine in the trunk look". So diameter variance not so noticeable.
I thought they looked great and filled out the wheel well beautifully. But they are extremely heavy and slowed her down. And it wasn't because of the added traction... She was 2 speed Jetaway and 3.23 limited slip, with over 100,000 miles. Went from a peel out on a dead punch to a chirp. Now she accelerated as if I had someone in the car with me when I was alone. If the engine was fresh with a robust drivetrain probably not much of an issue...
Fletchmo72
Wheels and Tires
Jun 26, 2021 05:29 AM
RT PLATE
Wheels and Tires
Sep 21, 2016 06:46 PM
rockdog2112
Nov 8, 2013 04:12 PM
brandon 455
Wheels and Tires
Nov 6, 2013 05:46 AM
gogolf0401
Wheels and Tires
Jul 14, 2011 01:48 PM
