Click Here
Largest wheel/tire on the rear of '66 F-85
Old Dec 23, 2010 | 06:19 PM
doc's Avatar
doc
My '66 F-85 four-door runs 15x7 steels w/ poverty caps & 236/60/15 all around.
The front is about perfect (car is really low on sagged springs), but I want to run a wider wheel tire combo on the rear.
I'm thinking of a 15x8 or 15x10 steel (still going to run the poverty caps) from Wheel Vintiques w/ a 255 or 275 tire.
Any ideas on backspacing, etc.?
Thanks!!
Doc
Old Dec 23, 2010 | 06:46 PM
Run to Rund's Avatar
I have both 15x8 and 15x10 custom made steel wheels that accept hubcaps and are the correct offset. I run the 30x9" Hoosier drag slicks on my 66, but had to go to other wheels that would accept 5/8" studs. That is why I can sell the ones with stock centers.
Old Dec 23, 2010 | 06:54 PM
doc's Avatar
doc
PM me some info if you're selling them.....
Thanks!
Doc
Old Jan 2, 2011 | 06:48 AM
|-K|=K's Avatar
I'm not sure the differences between the 66 and 64 but I've been playing with different setups on my '64 for the past year. I have not tried anything smaller than 18" but you might get an idea for placement with this info. Keep in mind the sidewall buldge is much more prominent on a smaller say 15" diameter rim.
On the rear:
8" 4.5" bs
8.5" 4.75" bs
9" 5.25" bs
9.5" 5.5" bs
10".... I just don't see it fitting with a proper tire size if the car is lowered or has OE springs sagging like mine.
I currently have a 22x9 on the rear with a 5.5" and it fits well but it would be better centered with a 5.25" backspace. The 255 tire I'm running fit just over flush with the wheel and I can stick my fingers between the tire and inner fender on the outside.... but it's closer on the inside near the frame and inner fender.
Old Jan 2, 2011 | 09:57 AM
On a 66, 15x8 works with 3.5 to 4" backspace. 15x10 needs 4.5 to 5" to be centered. The bigger the tire, the more the backspace matters.
Old Jan 2, 2011 | 11:35 AM
orange442's Avatar
Many people, including myself, have run and are currently running 255-60's and 275-60's on 7" wheels with no problem. So, unless you just want the wider wheel and want to spend the money, your 7" wheels will work just fine.
Old Jan 2, 2011 | 11:37 AM
doc's Avatar
doc
My reason is filling out the rear wheel wells.....car looks good (to me) except for the "tucked" rear w/ the 235/60's on stock GM 15x7.
Either way, thanks for the info guys!!
D
Old Jan 23, 2011 | 03:49 PM
ROBZ442's Avatar
I am running 15 x 10 Weld Stars on the back of my 66 442. The back spacing is 5" but there is room to go 6" back spacing without a problem. If I would have done this I could have tucked bigger tires or lowered the rearend more without rubbing.
Old Jan 25, 2011 | 01:36 PM
RAMBOW's Avatar
Ben
I have 15x8 w/ 4.25bs on the rear of my 66 and it could easily go out more. If i had wheels with 4.5 bs i think it would look a little better. They sit "in" a little too far for my taste.
I initally had 275/60's on the rear wheels, and they fit fine w/o rubbing (not even close). I have 255/60s on the rear now.
jkoester122
Wheels and Tires
81
Jun 15, 2017 11:59 AM
F-85 4-4-2
May 25, 2014 01:48 PM
Kyle's 77 Cutlass
Dec 24, 2013 01:17 PM
XTREMEGSXR
Wheels and Tires
May 10, 2012 02:30 PM
ss427
Jan 15, 2008 07:47 AM
