Which hubcaps?
Which hubcaps?
I am working on a 1968 4-4-2 convertible. It did not come with SS wheels, because it had the houndstooth cardboard spare tire cover. The wheels that were on it were black rollers, original unkown. Is there any way to discover the wheel cover it came with without the build sheet? I have the protectoplate, but no other paperwork. I am partial to the PA-1 hubcaps. Also, what code steel wheels should I look for to restore it? Thanks
These covers would look great on your 1968 442:
https://classicoldsmobile.com/forums...el-covers.html
Of course, I may be a little prejudiced, as they are mine......but I always thought they looked great on anything!
http://www.ebay.com/itm/1968-Oldsmob...-/301089656968?
For what it's worth, poverty caps and similar items are hubcaps.
But the others are wheelcovers - they cover the whole wheel.
Interesting bit of trivia I discovered a few years ago, as I tended to use the terms interchangeably.
true
Diego, You are correct technically, I can appreciate technical, I once started a riot when I got into a flaming argument with a supposed Olds guy who claimed pronouncing four forty two was OK! About the wheelcovers; The only wire wheels I like are the Kelsey-Hayes on 1954 Buick Skylarks and 1963 Thunderbirds. The reason I doubt it came with poverty caps is that none of the wheels were painted body color. I am thinking of two sets; Pa-1's on stock wheels & Coker tires and Cragar SS on nice fat tires for that vintage look.
Incorrect terminology makes it hard to locate what you want on an ebay search.
Henry
Searching eBay for parts can really be a hit and miss thing at times, even with search options set up. It takes a LOT of time to go through those searches too.
It makes it REALLY HARD to search if you are on dial-up as I am.....
Olds called them "wheel hubcaps" and "wheel discs".
Those wires look great on there; is that an original W-30 car? That's a pretty rare option!
A neighbor of mine bought a NEW '68 442 W-30 convertible in Jade Gold, and it was a beauty! Unfortunately, he hit a tree with it when it was only a couple of months old, and bent the frame, took months to repair, and I don't even remember what happened to it after that!
rustycragars
December 25th, 2016 06:06 PM
thomaswatk
March 22nd, 2007 01:31 PM
