correct Argent paint for 68 Super Stock II wheels.
Question: they are many Argent paints for 68-72 Super Stock II wheels on the market and of course everyone claims that theres is the correct one but who really does sell the correct one? Fusicks, Inline Tube and Thornton look like the best ones but at a maximum of $23.00 plus $8.00 shipping per can i want to know for sure. Anyone that as have experience with them?
I used SupercarsUnlimited SSII wheel paint, part number 52-216, for my niece's '68 4-4-2 and it looked darn close to me. It comes in 12oz spray cans. Supercarsunlimited deals solely with Oldsmobile Cutlass/4-4-2. Check their on-line catalog at supercarsunlimited.com for price.
Randy C.
Randy C.
Randy is that the gray or silver version? I'm told 68-70 used more of a silver and later years a darker gray color. If the lighter silver color, is that the same as used on the fender fillers and deck lid molding?
50 shades of Grey
That is exactly what i was wondering myself which Gray was used in 1968 as i will be painting a total of 10 Super Stock II wheels 5 are 14" and the other 5 are 15" of which one of the wheels still as the original (lighter Silver original paint) the other 4 are black as they were off of a 78 Cutlass . I plan on installing the 15" wheels once a wear out the tires on the 14" tires.
I guess i need to see pictures of how each shade looks on the automobile but i am leaning towards the Argent Gray as i believe it to be original to 68-70 4-4-2 automobile's. I like the matching color wheels to the automobile but i think the Argent Grey stands out more and it's original. Thank you for your replies. I appreciate it.
I stumbled on this site but it answers a lot of questions: http://www.oldsmobility.com/old/superstock.htm
As anyone used the Inline Tube SSII grey paint on there wheels? There price is $12.00 a can which is lower than Fusicks, Thornton, etc... but 64-78 all being the same doesn't sound correct and they don't post actual pictures of them painted (that would really help)
The color question has come up probably at least once a year. From all the time I've been involved and seen pics it also depends on what batch of paint was used on what day. Most of the SSIIs I have had have all been darker, I have seen pics of supposedly untouched spare rims ranging from 68 - 72 all with different hues of grey. I started a thread with some comparisons of the rims I had. I'll try to find it and post the link here.
Edit: https://classicoldsmobile.com/forums...option-112690/
Grays
It is my opinion that most likely all the grays out there are correct. All rims did not get painted at one plant, each guy hand mixing the paint would have caused some slight type of color change. Just look under your hoods, all black painted items do not look the same from the factory. Engine black has a color pulleys different color alt brackets, A/C brackets, but all call for the same color. All just my opinion. Best match is to pull a known virgin spare tire, and get it color matched at the local paint store, or buy the paint that is the best deal from one of the Olds parts outlets.
Ok, i ended up purchasing (2) cans from Inline Tube because $23.00 plus $8.00 shipping for (2) cans sounded reasonable and it was described as they did a lot of research and formulated there own paint and the picture showed there own label. I received (2) cans of Seymour 10-48 Cast Iron Gray which Seymour sells for $4.96 on there website (shipping not included) or you can buy it for $8.85 (including shipping) on Amazon. The paint is high quality and looks great, so great that i am going to paint all my wheels with it. With tires on the rim it was a challenge because i used paint stripper (be careful not to get any on the tires) than i used Mar-Hyde to turn the rust into a primer, i used grey primer on both sides, painted the inside of the rim with semi gloss black and the outer portion with Seymour 10-48 Cast Iron Gray. I am going to do all (4) wheels on the car (it's my spare in the picture) then i have a set of (5) 15" rims that i am going to paint as well for when i replace my tires (at the driving rate that i am going in i may be in the box by then). Finally i recommend this paint as it looks great and original and reasonably priced. It totally changes the look of the car!
Seymour Model #10-48 Cast Iron Gray
AFAIK, all the painted rims were originally black and the fronts were sprayed and there was no clear coat that I'm aware of. I've never seen it unless they were restored. If you do clear them, you would need to use some flattening agent or it would be too shiny IMO. And they didn't always give 2 craps about overspray blowing through the holes and getting on the inner rim. I personally wouldn't want any overspray on the back, but if some did get there, I wouldn't care so much. I can only imagine it was where the rim was painted and by who that day.
Interestingly, GM painted all the super stock wheel faces, even the chrome ones to some degree, as well as the SSI inlays. 69 H/O had a painted center with chrome outer rim. Later, in the 80s when they used the entire chrome wheel, they painted the inlays only either black, or silver (83/84 H/O), or gold (85-87 442). The reason for this is that chroming around the lugs wasn't able to be buffed up properly during the chroming process. So they simply painted over them. It was more aesthetically pleasing to the eye. Especially the SSI wheels, IMO. They used that same trick on chrome grille inlays and other hard to chrome parts. Rust around the lug holes is an issue with the chrome SSIII wheels. Moreso IMO than the painted versions. The chrome cracked around each lug hole and allowed moisture to get under it and lifting it.
Nice work, and thanks for the follow up pictures.
Great explanation
It give the automobile a new and better look as if you painted the bottom portion of the automobile but without spending a ton of money and getting the original look back. I have a set of (5) 15" X 7" rims without tires that i will paint once i finish my 14" x 7" set of (5). It all started from a flat spare tire in the trunk.
