Click Here
Cooper Cobra Radial G/T vs BF Goodrich T/A
Old December 29th, 2020, 07:01 PM
  #41
COBRA2000's Avatar
Sounds good, but I'll just remind you that I'm not the one who put a political commercial in my post.
I didn't... Have a good evening....
COBRA2000 is offline
Old December 29th, 2020, 09:36 PM
  #42
How many miles?
I'm not yet sure where this one's leaking from but I'm thinking valve stem area as that's where the others went. The leaky one on our Mazda SUV has already been repaired on warranty once but continues to leak.
Valve stems are not integral to the tire. I have about 10k miles on them.
oldcutlass is online now
Old January 1st, 2021, 06:15 PM
  #43
Funkwagon455's Avatar
[QUOTE=71 OLDS;1294180]Love the look of the BFG T/A's so much (especially with SSIs) I glued the letters on 18" x 305 Nitto drag radials in the rear and 18" x 245 Michelin Pilot 4S front. I have the high performance tires I want with the RWL look.
That is dedication man! Some folks buy TAs that have had the letters removed and redlines vulcanized on! If my car was ‘68 or earlier, I’d consider it
Funkwagon455 is offline
Old January 2nd, 2021, 08:53 AM
  #44
BlueCalais79's Avatar
Our 1969 Camaro is needing a new set of white letter tires. I have used Cooper Cobras for my 1972 Cutlass S and now a set is currently on my 1979 Hurst Olds. As much as I wanted Coopers on the Camaro, I'm going to have to go to BFG's since I really need to be putting a 205 series on the Camaro (it's a 6 cylinder). Anything more than that is just too much tire. The thinnest tire Cooper has in a 14 is 215. Too bad.
BlueCalais79 is offline
Old January 2nd, 2021, 10:02 AM
  #45
The difference between the 205 vs the 215 is 1/2 inch in the height and less than a 1/2 inch in width. I'd go with the 215's.
Old January 4th, 2021, 10:57 AM
  #46
While I'm piecing the history of this Hurst Olds together, I'm learning it was painted in 99, and had a chassis refurb later on. Not much else, it seems to have sat in collections or museums like the one I bought it from. Buying a car that sits on display a lot has its own challenges. These BFGs look great on the front side, but the bad side is dirty from years, and the three digit tire code of 397 means these rubbers are 23 years old, and it is time for new tires! (I knew they were old, but not THAT old.)
Will probably replace the BFGs with new BFGs. The 225 70 R14 looks good on the car and I will continue with that size. My rims are in good, but not flawless shape, so I will put the car on other wheels and mounted tires I have, take these loose, pull center cap and beauty ring, and I think I can leave the opening trapezoids trims on and I will follow the advice of a buddy of mine, which is go to the tire place in the black part of town with dub wheels in the window and they will have the best tire machine in town (see below for Evansville's version), so I'll go there with new tires and loose rims.
Can you put weights on the front on an SSII and have the trim ring work, or should they all be on the back side?
Koda is online now
Old January 4th, 2021, 11:26 AM
  #47
COBRA2000's Avatar
They put mine on the back side...
Old January 4th, 2021, 12:28 PM
  #48
They can be put on the front side as well. The trim ring will fit over them with no issues.
Fun71 is online now
Old January 4th, 2021, 02:28 PM
  #49
x2. With weights mounted on the inside only you got a static balance, about the same as a bubble balancer.
Old January 4th, 2021, 06:45 PM
  #50
I have since noticed I have some under the ring, so all is well with repeating that.
Koda is online now
oldcutlass
Wheels and Tires
26
December 15th, 2018 04:39 AM
gglow
August 3rd, 2018 07:26 PM
Magna86
Wheels and Tires
March 27th, 2014 06:44 AM
Mister
Wheels and Tires
58
October 27th, 2010 04:57 AM
Gaz Hog
June 29th, 2010 08:44 AM
Quick Reply: Cooper Cobra Radial G/T vs BF Goodrich T/A
