Click Here
72 Cutlass Center Cap fitment
Old July 10th, 2018, 03:29 PM
Cory
dream66's Avatar
Will this style center cap work on a 72 Cutlass wheel that normally has the bolt on cap"
dream66 is offline
Old July 10th, 2018, 03:41 PM
No. The bolt on cap is completely different as is the center wheel profile.
Allan R is offline
Old July 10th, 2018, 05:15 PM
72 Olds CS
RetroRanger's Avatar
There are ss2/3 bolt on center cap rims in 14 and 15 inch sizes and ss2/3 snap on center rims in 14 and 15" sizes as well. You have pictured an ss2/3 snap on center cap.
RetroRanger is offline
Old July 10th, 2018, 05:23 PM
Cory
dream66's Avatar
Okay... I need the bolt on cap and a member PM'd me with one. Yippee.
dream66 is offline
Old July 10th, 2018, 05:28 PM
The 14" and 15" bolt ons all use the same center cap though, same with the snap ons.
Allan R is offline
Old July 30th, 2018, 09:56 AM
Jcavall's Avatar
Help W Center Caps
Just got my new wheels and tires installed. Already lost 2 snap on caps that came w the used set.
Can reproduction bolt on caps be used on these rims?
Any thoughts or options would be appreciated!!
Jcavall is offline
Old July 30th, 2018, 10:39 AM
No, the bolt on caps are a completely different design and fitment. Plus the wheel is not configured for bolt on caps. If you lost 2 snap on caps, I would suggest the snap rings weren't on properly. Check they are tight and perhaps ben out the lock tabs a bit to make sure they hold in place. Its not uncommon for snap on caps to develop loose attachment rings.
Allan R is offline
Old July 30th, 2018, 10:42 AM
See the difference between the bolt on compared to your wheel? This picture shows it very well.
Allan R is offline
Old July 30th, 2018, 12:51 PM
Agreed. I bent the tabs on my wheels so they fit very tightly to ensure they stayed on.
Fun71 is offline
Old July 31st, 2018, 09:54 AM
Jcavall's Avatar
Thank you both!! I was assuming they were different. I see by the pic. I was also thinking I could retrofit existing to bolt on.
I think I will just order a new snap on set and see how that goes 1st.
Thanks again!!
Ken you and I have the same car, but mine is triple black.
Jcavall is offline
Old July 31st, 2018, 12:38 PM
Be careful which vendor you choose. Some of them are charging an arm and a leg. I see them at OPGI for close to $100/cap ! Fusick has them for $55.00/cap or $189/set of 4 which breaks down to $47.25 each. I hate Fusick shipping though - they really gouge.
SupercarsUnlimited sells them for $50/cap
Inlinetube sells for $49/cap
BTW, the snap on center caps won't be in the 72 and under catalogue as prior to 73 everything was bolt on. Source 73+ in your search.
Allan R is offline
Old July 31st, 2018, 01:08 PM
4speed455's Avatar
https://www.ebay.com/itm/1974-87-Old...d=m570.l1313It
The Parts Place has 4 new snap on caps for $155 with free shipping on eBay.
4speed455 is offline
Old July 31st, 2018, 02:11 PM
Jcavall's Avatar
Ordered them on Ebay. Thanks 4speed455!!
Jcavall is offline
Old August 1st, 2018, 11:11 AM
4speed455's Avatar
When you get them let us know how they are. I'm curious if the emblem is just a flat decal or if they are beveled with the clear acrylic over them like the originals. I bought new decals for my caps and they were just flat metal stickers. They look decent but I will probably swap them out with theses.
https://www.ebay.com/itm/Oldsmobile-...AAAOSwal5YCA4-
Old August 1st, 2018, 11:36 AM
If you use the 'zoom' feature on the fleabay site the image looks like the centers have raised surfaces. Not as crisp as OEM but still nice.
Allan R is offline
Old August 1st, 2018, 01:59 PM
Jcavall's Avatar
Per the description. I will post a pic when I get them.
This is a set of 4 wheel center caps for a 74-87 Cutlass. These caps are the SSIII snap on style, featuring a raised rocket insert in red and silver just like original (not the cheap smooth decal). The chrome on these caps are very nice, these have been discontinued from GM for some time now. These are brand new center caps perfect for your restoration. Stock is limited. Fits: 1974-87 CUTLASS " S " 442 W-30 W-31 SUPREME HURST OLDS models. Sold as a Set of 4
Jcavall is offline
Old August 1st, 2018, 03:58 PM
4speed455's Avatar
So my original emblems on my caps are actually flat and appear to have a thick clear acrylic coating. The repro emblems are embossed metal with no clear acrylic coating and have the raised rocket logo. My original caps that I am basing this off are 80’s vintage so this may not be correct for all snap on caps. Did they change the emblem at some point? I thought the thicker flat ones were correct.
Old August 1st, 2018, 04:03 PM
I have a set of snap on center caps for one set of wheels. They are in NOS condition and I bought them straight from GM back in the day. They still look new and they don't have the embossed surface. They are completely flat on the emblem and are crisp outlines like 4speed455's. Noticeable differences with OEM center caps are:
  1. The surface of emblem is flat
  2. The emblem is more a blood red than the vivid red on the reproductions
  3. There is a GM part number cast on the inside.
Allan R is offline
first442
July 9th, 2019 04:21 PM
first442
May 28th, 2019 08:40 PM
Alex72cutty
April 19th, 2013 05:24 AM
lshlsh2
May 12th, 2011 05:02 AM
stevengerard
Wheels and Tires
November 28th, 2009 04:37 PM
Quick Reply: 72 Cutlass Center Cap fitment
