Click Here
Tire Size
Old Aug 7, 2018 | 06:06 AM
kbdecatur's Avatar
Tire Size
I'm looking into buying a set of ss1 wheels 15x8. Is there anyone here running the same size and if so what tire size did you go with? Thanks in advance..
Old Aug 7, 2018 | 06:13 AM
oldsmobiledave's Avatar
need more info
You need to say what car you are mounting these on. Also are you running 15x8" on all 4 corners or just out back?
Post more details FIRST
Old Aug 7, 2018 | 06:15 AM
kbdecatur's Avatar
It’s a cutlass and I’m running 15x8 on all 4 72. Hope this is enough info.
Old Aug 7, 2018 | 06:17 AM
What look are you after? Big in back, little in front or all 4 the same size?
Old Aug 7, 2018 | 06:19 AM
kbdecatur's Avatar
Same all the way around is fine with me.
Old Aug 7, 2018 | 06:52 AM
This will give you some ideas
https://classicoldsmobile.com/forums...ost-yours.html
Old Aug 7, 2018 | 10:00 AM
tires
255 60 15s all around is the biggest. Personally I think that 255 60 15s up front is too big on the front.
I prefer 275 60 15s out back on 15 x 8s & 225 70 15s up front on 15 x 7. Have also run 245 60 15s up front on 7s.
Good luck with what you decide.
Old Aug 7, 2018 | 10:24 AM
svnt442's Avatar
Running a 15x8 on the front is going to cause rubbing issues unless your tires are REALLY short and I don't recommend that. I'd say a 15x8 on the rear and a 15x7 on the front.You can do a 275/60/15 on the rear a 225/70/15 on the front. Or maybe a 295/50/15 with a 235/60/15.
Old Aug 7, 2018 | 10:49 AM
droptopron's Avatar
delete
Unless the SS1 are aftermarket or widened, they'd be 15x7. Double check.
Old Aug 7, 2018 | 12:34 PM
RetroRanger's Avatar
72 Olds CS
Ive got 255-60-15s on 15x8 at all four corners. I might get minor rub at the extremes but its infrequent and not an issue imo
72 supreme
Old Aug 7, 2018 | 05:35 PM
Qwik71442's Avatar
Full-time Taxpayer
72 supreme
x2 I have 15x8 all around with 255/60’s with no issues. you can also use the 245/60 in front if you have the slight rub issue.
Old Aug 7, 2018 | 06:31 PM
anthonyP's Avatar
SS-1 wheels: 15x8 in the back and 15x7 in the front. 275/60 or 255/60 in the back. 235/70 or 225/70 in the front.
zeeke
Mar 21, 2018 04:15 PM
Johnnylindo
Jan 26, 2018 05:12 PM
ctrain22
Aug 20, 2009 04:47 AM
woodie582
Sep 1, 2008 12:26 AM
