Click Here
5.29 backspacing on front and rear
Old Nov 15, 2019 | 08:21 PM
yeahbuddy's Avatar
What kind of issues can I run into running a wheel set with 5.29 backspacing. Got a nice set that are 17x8 ET20. When I plug it into the calculator it tells me 5.29 backspacing.
Old Nov 16, 2019 | 05:33 AM
I have no idea what calculator you are using, but 5.29 backspace (I assume that's inches) on an 8" wide wheel is about one inch of positive offset. That pushes the tires to the inboard side of the wheel well by an inch. On a RWD Olds, you typically want close to zero offset. For an 8" wide wheel, zero offset translates to 4.25" to 4.5" of backspace, depending on the specific contour of the lip of the wheel.
Old Nov 16, 2019 | 11:31 AM
yeahbuddy's Avatar
I having been researching this for a few weeks and a lot of threads that go over what I am doing in the Chevelle forums call for 5.5". I found a couple threads on here calling for 5.5". I used the tiresize.com calculator to compare what was on the car to what is going on the car.
Before I get flamed, I wanted a set of CCW LM20 wheels but I cant afford those right now so these BBS wheels will do for now. I am going to change the tire sizes but these are the tires that came with the 2-piece wheelset I picked up. I am tired of the 275/6015 on the rears which required me to get air shocks to stop rubbing..they are just too tall. I am going to just put these 2 piece wheels on and go with Blistein all around. I want to go with a 275/40 all around
The specs on these wheels are as follows:
F: 5x120 ET20 17x8
R: 5x120 ET20 17x9
FRONT
REAR
Zr1bandit
Jun 10, 2017 11:26 PM
midnightleadfoot
May 15, 2017 07:57 AM
Foss604
Wheels and Tires
15
May 17, 2015 08:11 PM
mikeybee455
Mar 28, 2015 07:16 PM
72cuttys
Wheels and Tires
Sep 29, 2013 09:50 AM
