Click Here
275/60/15 on a 15x10 rim
Old January 13th, 2018, 05:43 PM
sschevellecutlass_Bob's Avatar
I see the recommended width for 275/60/15 is 9.5, but does anyone run the 275 on 15x10 rim? Would it work ok?
sschevellecutlass_Bob is offline
Old January 13th, 2018, 09:33 PM
Mr Nick's Avatar
They will work fine on a 10" wide rim, that is a popular combo.
Mr Nick is offline
Old January 14th, 2018, 01:20 PM
Chevy budget Olds powered
coppercutlass's Avatar
works great. Gives a drag radial a more bias ply look it also gives it like an extra 1n. of foot print. Guys have ran em on 12 in wide but with bead locks.
coppercutlass is offline
Old January 14th, 2018, 03:36 PM
oldsmobiledave's Avatar
rim width
The recommended rim width for a 275 60 15 is 7.5"-9.5" with 8.5" being optimal.
Personally I like them on 8-9" rims but you should be absolutely fine on a 10" rim.
oldsmobiledave is offline
Old January 14th, 2018, 08:01 PM
Thank you all very much. I have 295 50 15 on now. looks ok, but too short. Was thinking of trying the one 325 50 15 in the garage (tried it on chevelle but sidewalls looks to baloony). but that might be toooo big. the 265/50/15 has height and width on 10" rim, so that may be it. especially after seeing bad a$$ pictures above. Looks fantastic. great rake too.
Old January 14th, 2018, 08:32 PM
265 50 15?
Who makes a 265 50 15?
Old January 14th, 2018, 08:44 PM
total typo on my part.....275/60/15. Don't ask me how the hell I typed 265/50/15. And I don't drink or take drugs.
Old January 15th, 2018, 11:11 AM
Thanks. Personally I want the back lower like 1.5 inches but my driveway has a short steep entry to the flat and I have to tuck my exhaust up a little more and re do my driveshaft safety loop.
Old January 15th, 2018, 08:36 PM
Stance
you probably want the 295/50/15 look. The back stays in that take off look. I like the back up just a little... I have 295/55/15s on Chevelle and air shocks for when I throw on the 325s. Want to keep the Cutlass wide but not E/T Street or huge as the engine doesn't have the power (yet). Will be putting white super stock rims as Cragars do it for me on the Chevelle but not my Cutlass.
Old January 16th, 2018, 05:44 AM
I meant as in lower the suspension. The 295's are too short to wide. The 325's will eat up some power. I like the 275 60 15
Old January 16th, 2018, 08:34 AM
my 2 cents
275 60 15s is the right size. If you are not hooking on a 275 you need suspension work.
Old January 16th, 2018, 09:57 AM
Im still hooking on yhe 275 but need suspension work now that i went to a 3500 stall. But i think the adjustable uppers, lift bars and 80/20's in the front should do the trick along with coil overs in the rear.
Old January 18th, 2021, 07:46 AM
teamwieland's Avatar
Changing my ‘68 442 to 28” tires from stock for a few reasons. Clearance coming in my driveway and moving from 3.23s to 4.10s. 28” tires look good and accomplish my goals. Do the stocks 15” SSIIs Work or are there cost effective lightweight alternatives that would work better, particularly on rear 275/60/15s? I’m not opposed to going a little narrower on fronts as I’m looking to run some quarters this summer. I like the look at AR Torq Thrust wheels although those may not be any lighter than stock.
teamwieland is offline
Old January 18th, 2021, 07:50 AM
Weld pro stars and centerline's will be the lightest wheels for the lowest price. As far as tires in the front the mickey thompson S/R radials are light and will get you home safely. In the back a 275 60 15 drag radial from Mickey thompson should be plenty depending on power and suspension mods
Old January 18th, 2021, 12:23 PM
I had 275 60 15's on factory Buick Rally's with Oldsmobile center caps. Hooked great. Looked great. Zero issues.
no1oldsfan is offline
Old January 18th, 2021, 02:53 PM
Funkwagon455's Avatar
As per the original poster’s question posed, I am also curious as to potential problems with using a 10” wheel. What would be the drawbacks or safety concerns using the 275/60? I have always intended to purchase 295/50’s but am intrigued at the idea to add just a little height and sacrifice width. I don’t want to consider it if there will be problems induced though. Trying to do due diligence...
Funkwagon455 is offline
Old January 18th, 2021, 03:06 PM
It will work just fine. Half inch ain't nothing. I ran mine on the track just like that no issues
Old January 19th, 2021, 10:08 AM
Copper, I’m sure you’ve probably mentioned this elsewhere, but could you tell me your offset on those 10’s? Also, my wheels are heavy. 26# per each, but then again I’m not overly concerned with time slips.
Old January 19th, 2021, 11:00 AM
5.5 works best with the 15x10 on the A body 70-72
Old January 19th, 2021, 11:13 AM
Thank you sir!
Old February 21st, 2021, 05:13 PM
Here is the final result:
Old February 21st, 2021, 05:18 PM
It looks fantastic Bob, just to be clear are these 295/50 or 275/60? Thank you
Old February 21st, 2021, 05:21 PM
275/60/15
Old February 21st, 2021, 05:25 PM
Thank you sir!
Seff
Wheels and Tires
25
June 21st, 2023 07:00 AM
PM70
September 25th, 2017 07:28 PM
Levellord
Wheels and Tires
November 19th, 2016 06:29 AM
Oldsragger
Wheels and Tires
May 27th, 2015 12:09 PM
s i 442
Wheels and Tires
August 1st, 2013 04:55 AM
Quick Reply: 275/60/15 on a 15x10 rim
