Click Here
1964 Cutlass Tire/Wheel Size Fitment
Old Feb 28, 2022 | 08:06 AM
harleyrules's Avatar
I have a 64 Cutlass and I acquired a set of Wheels Vintiques similar to the SS2 style wheel. They are 14x7 I believe 4 1/4 back spacing. What size tire can I put on these rims that will not cause any tire rubbing on the front fenders? I also have Oldsmobile SS2 14X6 rims what size tire for these if that would be a better option for no tire rubbing?
Old Mar 1, 2022 | 07:24 PM
Given the extremely limited choices in 14" tires today, unless you want to pay big bucks for Coker repros, the 225/70-14 is about the largest commonly available tire. These are just about the same outside diameter as the originals so they fill the wheel wells nicely. Yes, BFG sells a 245/60-14, but it's an inch smaller in diameter and barely 3/4" wider than the 225/70. Those 245/60s leave a lot of daylight in the wheel wells in my opinion. The BFG Silvertown redline 225/70-14s look really nice, but since Coker took over distribution the price has gone through the roof.
Old Mar 4, 2022 | 07:03 AM
Thank you Joe, what off set would be the best so it doesn't rub the edge of the front fender?
Old Mar 4, 2022 | 08:36 AM
If you're using the 14" that you have there is no issue on offset, just the diameter of the tire. You may have rubbing issues if you use a P225-70-14 up front. As far as purchasing new wheels, backspacing and offset are based on the wheel width you choose.
Old Mar 4, 2022 | 08:42 AM
Offset should be zero, which is what the stock wheels had.
Old Mar 4, 2022 | 11:48 AM
Gerald Nickels's Avatar
Why not go to a 15" rim I used the Olds 15X7 rims on my 64 F-85 drag car with 29" tall slicks. Never rubbed.
Old Mar 4, 2022 | 03:03 PM
dbater's Avatar
I believe he is referring to a front fender interference.
Old Mar 4, 2022 | 05:37 PM
Correct, Front fender interference/clearance concerns.
I have 14 rims on hand, 15 inch would be an added expense but if I found a deal well different story,
Old Jun 25, 2022 | 07:04 AM
Ok, I mounted the Wheels Vintiques similar to the SS2 style wheel with the 215/75R14 redline tires that came on them onto my 64 Cutlass. The front tires will hit the fender when making a sharp turn. Which tire would work better so nothing hits? Also can anyone tell me what the correct height from the ground to middle of fender should be in case I have weak springs?
Thank you
Old Jun 25, 2022 | 07:42 AM
The optional oversize tires on the 1964 cars were 7.50x14, which were 27" in diameter with a 7.65" section width. 215/75-14s are only 26.7" in diameter with an 8.46" section width. With zero offset wheels they should clear fine.
Old Jun 25, 2022 | 07:56 AM
Joe,
How do I determine if these wheels have a zero offset or not?
Old Jun 25, 2022 | 08:10 AM
Joe,
With a ruler and some math.
For zero offset, the backspace minus the lip thickness should be half the rim width. This puts the wheel mounting surface exactly in the center. If the backspace minus lip thickness is greater than half the width, that's positive offset that pulls the tire inboard towards the frame rails. If smaller than half the width that's negative offset that pushes the tire outboard towards the wheel opening.
This illustration is showing negative offset, as the wheel mounting surface is closer to the backside than the front side of the wheel.
Old Jun 25, 2022 | 08:28 AM
Joe,
Thank you. I'll measure the rims tomorrow and see what I have. If they are in fact zero offset and the tires are rubbing the fender then I guess the front springs are sagging?
Old Jun 25, 2022 | 08:34 AM
The carrying height measurements for the car are on Page 9-108 of the 1964 Chassis Service Manual. The height is measured from the ground to the flat portion of the bottom of the rocker panels. The car should be parked on a flat, level surface. The front height is measured just behind the start of the rocker panel aft of the front fender and should be 10". Rear is measured just in front of the rear wheel opening and should also be 10". Note that this is with the OEM tire size. Different tires will obviously change the measurement. It's probably more important that they are equal than that they match the listed numbers.
Old Jun 25, 2022 | 08:58 AM
Joe,
Thank you, the front is at 10 inches the rear is at 10.5 inches but the rear has air shocks which raised it some.
Old Jun 25, 2022 | 09:07 AM
Joe,
So ride height isn't the issue.
Old Jun 25, 2022 | 09:49 AM
Ok, then I guess it will be the rims. I'll know better when I measure them tomorrow.
Thanks again for your assistance Joe
Old Jun 27, 2022 | 08:40 AM
Ok Joe,
I measured my rims and I have a positive offset of approx 1 inch. The wheel mounting surface is closer to the outside of the rim then the inside. So where do I go from here? Why would the front tires rub the fender when making a sharp turn?
Old Jun 27, 2022 | 08:43 AM
Does your car have a disc brake conversion? Those typically push the wheel mounting surface of the hub outboard.
Old Jun 27, 2022 | 09:10 AM
No sir, stock drums all 4 corners.
twiggy
Jan 11, 2019 06:09 PM
w-30dreamin
Wheels and Tires
Mar 8, 2017 10:49 AM
61reoldsman
Wheels and Tires
Jan 8, 2013 09:21 AM
Brians64f85
Wheels and Tires
Nov 15, 2012 11:53 AM
badass72cutlass
Wheels and Tires
Aug 28, 2012 11:13 PM
