Click Here
15x7 w/ 275/60 and 245/60
Old Feb 28, 2021 | 05:46 PM
tgilligan's Avatar
Am I able to comfortably run 275/60 on rear and 245/60 on front with 15x7 aftermarket wheels with a 4” backspace? Would there be room to run 275/60 on all 4 wheels?
Old Mar 1, 2021 | 05:00 AM
VC455's Avatar
Barely Registered
I'm assuming this is for the 1970 Cutlass in your photo...
I run 255/60-15 on 15x7s in the front and 275/60-15 on 15x7s in the rear.
I need to be a bit careful on the front when turning full lock over a bump, otherwise the tread catches the stainless wheelhouse trim. Cutting speed is all I need to do to prevent this.
The rear has lots of room.
I've not tried it, but I think 275s up front might present problems.
Old Mar 1, 2021 | 05:17 AM
tgilligan's Avatar
Thanks. Are you running a 4” backspace as well?
Old Mar 1, 2021 | 01:07 PM
VC455's Avatar
Barely Registered
My wheels have 4.0" backspace.
Old Mar 1, 2021 | 02:12 PM
tgilligan's Avatar
Perfect thanks. That’s exactly the advice I was looking for, much appreciated.
olds68442
Jan 22, 2022 03:49 PM
yellowrocket
Wheels and Tires
May 6, 2019 04:46 PM
RT PLATE
Wheels and Tires
Sep 21, 2016 06:46 PM
mbolds
Feb 8, 2015 12:10 PM
501Paratrooper
Wheels and Tires
Jan 18, 2014 11:35 AM
