92 Custom Cruiser Climate Control
New to olds ownership here, having a problem with my 92 cruiser. I have a fault code being stored in my climate control unit but cannot seem to enter the diagnostic mode to retrieve the fault.
From searching I found to turn ignition on, hold temp up and off for up to 5 seconds but it doesn't work. The buttons work normally so I know they function.
Any suggestions?
Any suggestions?
Did you pull codes from the ALDL by using a paperclip to short the A & B terminals together? That's a place to start.
Check it out!
https://classicoldsmobile.com/forums...mputer-123831/
Check it out!
If it has the electronic AC control there should be a small letter F with a degree symbol and if it is flashing on and off that means low refrigerant was detected. This must be cleared as it locks out the compressor. Must add refrigerant, The Factory Shop manual has the procedure.
Do you know how it monitors low refrigerant? from what i can see in the electrical diagram, both pressure switches are on the output side of the circuit and also go through a relay, unsure how the climate control is able to monitor it.
Thanks!
