92 Custom Cruiser Climate Control
Old Sep 7, 2023 | 06:18 PM
E-TwentyEight's Avatar
New to olds ownership here, having a problem with my 92 cruiser. I have a fault code being stored in my climate control unit but cannot seem to enter the diagnostic mode to retrieve the fault.
From searching I found to turn ignition on, hold temp up and off for up to 5 seconds but it doesn't work. The buttons work normally so I know they function.
Any suggestions?
Old Sep 8, 2023 | 03:00 AM
Did you pull codes from the ALDL by using a paperclip to short the A & B terminals together? That's a place to start.
Check it out!
https://classicoldsmobile.com/forums...mputer-123831/
Old Sep 8, 2023 | 04:44 AM
Oldsmaniac's Avatar
If it has the electronic AC control there should be a small letter F with a degree symbol and if it is flashing on and off that means low refrigerant was detected. This must be cleared as it locks out the compressor. Must add refrigerant, The Factory Shop manual has the procedure.
Old Sep 8, 2023 | 05:46 AM
That's exactly what happened, cycled the key and it allowed a/c again. at one point i was fiddling around pushing buttons trying to get it in to diag mode and i stopped to check my phone and looked back and it entered the mode, but I have no idea what made it work all of the sudden. was able to clear fault 09 (low refrigerant) but can't get back in to diag mode again.
Do you know how it monitors low refrigerant? from what i can see in the electrical diagram, both pressure switches are on the output side of the circuit and also go through a relay, unsure how the climate control is able to monitor it.
Thanks!
Old Sep 8, 2023 | 12:18 PM
Oldsmaniac's Avatar
Service manual says press ext temp and hold while pressing off to enter diagnostics
Old Sep 8, 2023 | 04:25 PM
Funkwagon455's Avatar
Factory service manuals are a HUGE help with maintaining and troubleshooting these vehicles and are very readily accessible/affordable right here on this site.😃
Old Sep 11, 2023 | 08:40 PM
I will have to get one asap, from using the google all I found was temp up and off button.
Oldsguy
May 31, 2023 03:11 AM
71Custom
Cars Wanted
May 2, 2022 06:47 AM
slickdriver
Vista Cruiser & Wagons
Jun 28, 2018 06:04 AM
tobywoodard
Dec 19, 2012 01:36 PM
ty wallace
Jan 30, 2009 06:03 AM
