Windshield compatibility between 1972 Olds models
I'm looking around for a sunshade for my 72 VC - they seem to be non-existent. However, I found one online for a 72 Cutlass. Is the windshield the same?
Thanks,
John
Thanks,
John
They should be identical. The front of the VC right back to the B pillar is interchangeable with other Olds A body post sedans, and the window trim is compatible with all the Cutlass A bodies.
Hmm, I just checked some glass company links I have. They show different glass for sedans and holiday coupes.
Check this link: http://www.autocityclassic.com/1970-...le-4-dr-wagon/ It's specific for 70-72 Chevelle wagons which must be similar. Call them and ask about the application for VC.
The 4 door cars have a taller windshield than a regular cutlass coupe or hardtop.
If if they are telling you the same for a 4-door, I would make sure. I think the 4-doors are about an 1” taller if I remember correctly.
FYI- Here is the thread where I had asked some questions about it.
https://classicoldsmobile.com/forums...970-bodys.html
Since, they were telling you same as 4-door, you are probably ok.
