Vista Fuel tank.
Old May 5, 2026 | 04:27 PM
Kajun442's Avatar
Vista Fuel tank.
Is this the correct tank for a 1971 Vista Cruiser? First time this has come up while searching for a tank and sending unit.
Old May 5, 2026 | 05:01 PM
Not even close, A body Wagons have gas tank up in rear fender.
Old May 5, 2026 | 05:13 PM
Kajun442's Avatar
Fuel sending unit hole in picture is top of tank. Tube facing down in picture would face outward towards fuel door. See Section 8 page 106 of 1971 assembly manual. I sure hope I'm right.
Old May 5, 2026 | 05:59 PM
Still not even close. A-body cars do NOT use the same tanks as do B-body cars. All A-body tanks are 20 gallons, not 22. Also 1970 Impala wagon is completely different from the 1971-up clamshell wagons. And Delta 88s are not even close to using the same tank as a Custom Cruiser. Run, don't walk away.
As more proof, here are the fuel tank listings from the Jan 1972 edition of the Olds parts book. 6800 series is the Custom Cruiser. Note that it's tank is unique. Also note that for 1970, the wagon and Vista tanks are different if you have the evaporative control system (EES) or not.
Old May 5, 2026 | 06:33 PM
Kajun442's Avatar
Thanks for the reply. Kinda hoping you would. I was skeptical about A and B bodies sharing the same tank.
70vista
Vista Cruiser & Wagons
Aug 28, 2025 05:53 AM
Furbody
Jul 21, 2025 02:10 AM
Toocool
May 8, 2020 05:22 AM
krauser65
Dec 26, 2018 09:08 PM
oldsvista_65
Dec 26, 2018 09:04 PM
