Custom Cruiser Key Fobs.
Old Oct 12, 2021 | 04:51 PM
oldsmike1972's Avatar
I have a1992 OCC.
When I bought it, it had no Fobs or original keys.
I bought a Fob on eBay, it is the car version.
I plan on getting a second set along with a proper pair of keys.
Anyone know the proper Fob for the OCC?
Thanks in advance for input!
Old Oct 13, 2021 | 04:38 AM
Beautiful OCC!
I'm not certain that those are the OE key fobs for your OCC but if the one you have syncs with the car I'd buy another. Especially if it has the Oldsmobile rocket on it. FWIW, these are the key fobs my 96 98 uses.
Amazon Amazon
Be aware that if your OCC has VATS the ignition cylinder will probably eventually wear to the point that you have a no-start condition. The VATS keys have an embedded resistor chip. Here's a good video on bypassing VATS.
Old Oct 13, 2021 | 06:22 AM
Thanks for the input Jesse.
Thanks for the kudos too.
I will probably just get the car version of the fob as I know that one works.
It has part number 12522338 on the Fob.
I don't have VATS, thankful for that!
Old Oct 31, 2021 | 10:34 PM
Fred Kiehl's Avatar
The fob will have a model/FCC ID ending with 103T (91-93) on the back. the ones with 104T (94-96) may also work. The corresponding receiver has the same number with an R at the end. 91 receivers have gray connectors, 92-93 have green connectors, and 94-96 have black connectors. I have not checked as to the interchangability of the receivers. The Oldsmobiles do not have VATS, so that is not an issue.
Old Nov 1, 2021 | 04:23 AM
As always, Thank You for your input, Fred!
Old Nov 1, 2021 | 12:11 PM
Funkwagon455's Avatar
104T works as well.😀
Old Nov 2, 2021 | 06:22 PM
Fred Kiehl's Avatar
I have 4 of the 104T Olds sedan fobs. I would sell them fo $15 plus shipping each.
RandyS
Jun 9, 2021 08:49 PM
DesertDweller
Mar 31, 2021 06:19 PM
matt69olds
Apr 22, 2020 07:46 PM
72455
Jan 6, 2019 12:56 PM
Funkwagon455
Vista Cruiser & Wagons
Dec 18, 2017 06:10 AM
